I’m trying to read data from my meter through a Wemos d1 mini. The yaml I am using is this:
> esphome:
> friendly_name: Chint Meter
> esp8266:
> board: esp01_1m
> # Enable logging
> logger:
> baud_rate: 9600
> # Enable Home Assistant API
> api:
> encryption:
> key: "***"
> ota:
> password: "***"
> wifi:
> ssid: !secret wifi_ssid
> password: !secret wifi_password
> # Enable fallback hotspot (captive portal) in case wifi connection fails
> ap:
> ssid: "Wemos Fallback Hotspot"
> password: "***"
> captive_portal:
> external_components:
> - source:
> type: git
> url: https://github.com/esphome/esphome
> ref: dev
> components: [ modbus, modbus_controller ]
> uart:
> tx_pin: 0
> rx_pin: 0
> baud_rate: 9600
> stop_bits: 2
> modbus:
> send_wait_time: 2000ms
> modbus_controller:
> - id: epever
> address: 0x24
> modbus_id: modbus1
> setup_priority: -10
> update_interval: 10s
> sensor:
> - platform: modbus_controller
> modbus_controller_id: epever
> address: 0x2000
> unit_of_measurement: "V"
> register_type: holding
> skip_updates: 30
> value_type: S_DWORD
> accuracy_decimals: 1
> lambda: |-
> union My_un {
> char temp[4];
> float foo;
> } un;
> un.temp[0] = data[3];
> un.temp[1] = data[2];
> un.temp[2] = data[1];
> un.temp[3] = data[0];
> ESP_LOGI("", "foo=%f , 0x%2x%2x%2x%2x%" ,un.foo,un.temp[0],un.temp[1],un.temp[2],un.temp[3])
> ; return un.foo ;
> address: 0x2004
> unit_of_measurement: "W"
> value_type: S_DWORD
> lambda: |-
> union My_un {
> char temp[4];
> float foo;
> } un;
> ; return un.foo ;
> filters:
> - multiply: 1000
I can’t read the data. From the log file I get this:
> [17:56:07][W][modbus_controller:112]: Duplicate modbus command found: type=0x3 address=8196 count=2
> [17:56:07][D][modbus_controller:029]: Modbus command to device=36 register=0x2004 countdown=0 no response received - removed from send queue
> [17:56:27][W][modbus_controller:112]: Duplicate modbus command found: type=0x3 address=8196 count=2
> [17:56:27][D][modbus_controller:029]: Modbus command to device=36 register=0x2004 countdown=0 no response received - removed from send queue
Can someone help me? Thank you
