Data logger from meter Chint DDSU666
I’m trying to read data from my meter through a Wemos d1 mini. The code i am using is this:
>  esphome:
>   friendly_name: Chint Meter
> esp8266:
>   board: esp01_1m
> # Enable logging
> logger:
>   baud_rate: 9600
> # Enable Home Assistant API
> api:
>   encryption:
>     key: "***"
> ota:
>   password: "***"
> wifi:
>   ssid: !secret wifi_ssid
>   password: !secret wifi_password
>   # Enable fallback hotspot (captive portal) in case wifi connection fails
>   ap:
>     ssid: "Wemos Fallback Hotspot"
>     password: "***"
> captive_portal:
> external_components:
>   - source:
>       type: git
>       url: https://github.com/esphome/esphome
>       ref: dev
>     components: [ modbus, modbus_controller ]
> uart:
>   tx_pin: 0
>   rx_pin: 0
>   baud_rate: 9600
>   stop_bits: 2
> modbus:
>   send_wait_time: 2000ms
> modbus_controller:
>   - id: epever
>     address: 0x24
>     modbus_id: modbus1
>     setup_priority: -10
>     update_interval: 10s
> sensor:
>   - platform: modbus_controller
>     modbus_controller_id: epever
>     address: 0x2000
>     unit_of_measurement: "V"
>     register_type: holding
>     skip_updates: 30
>     value_type: S_DWORD
>     accuracy_decimals: 1
>     lambda: |-
>       union My_un {
>         char temp[4];
>         float foo;
>         } un;
>       un.temp[0] = data[3];
>       un.temp[1] = data[2];
>       un.temp[2] = data[1];
>       un.temp[3] = data[0];
>       ESP_LOGI("", "foo=%f , 0x%2x%2x%2x%2x%" ,un.foo,un.temp[0],un.temp[1],un.temp[2],un.temp[3])
>       ; return un.foo ;
>     address: 0x2004
>     unit_of_measurement: "W"
>     value_type: S_DWORD
>     lambda: |-
>       union My_un {
>         char temp[4];
>         float foo;
>         } un;
>       ; return un.foo ;
>     filters:
>       - multiply: 1000
I can’t read the data. From the log file I get this:
> [17:56:07][W][modbus_controller:112]: Duplicate modbus command found: type=0x3 address=8196 count=2
> [17:56:07][D][modbus_controller:029]: Modbus command to device=36 register=0x2004 countdown=0 no response received - removed from send queue
> [17:56:27][W][modbus_controller:112]: Duplicate modbus command found: type=0x3 address=8196 count=2
> [17:56:27][D][modbus_controller:029]: Modbus command to device=36 register=0x2004 countdown=0 no response received - removed from send queue
Can someone help me? Thank you
