- id: Buongiorno info HUB
alias: Info
initial_state: true
- platform: time
at: '13:45:00'
condition:
- condition: state
entity_id: input_boolean.mauhome
state: 'on'
- service: tts.google_translate_say
entity_id: media_player.studio, media_player.sonos_stereo
data_template:
message: >-
Sono le {{states('sensor.time')}},
ed è {{states('sensor.dark_sky_summary')}}.
La temperatura esterna è di {{states('sensor.temperature_158d0001b95f60')|int|string }} gradi,
mentre la temperatura interna è di {{states('sensor.temperatura_media_casa') |int|string }} gradi.
*Previsioni.* {{ states.sensor.dark_sky_hourly_summary.state }}.
*Citazione. * {{state_attr('sensor.wikiquote', 'entries')[-1].summary|striptags}}.
It doesn’t work and if i try to trigger it from the services i get:
data_template:
message: >-
Did you rename the TTS service in your config? It should print a “service not found” error if you use a non-existent service but who knows at this point. Post your TTS config if you’re not sure what I’m talking about.
Wow! It failed with that very basic example? Strange.
EDIT
I agree with Tediore that there may be something fundamentally wrong and the data_template error is misleading but the only way the service can express the underlying flaw.
Based on the recent problems you’ve been experiencing, I would say more than just a bug and possibly a systemic problem with your instance of Home Assistant.
You’re right but as i moved to hassio i am fixing all the errors i had previously. Now all seems working as expected. I fixed the google_calendar error, the side_panel in hassio and the mqtt_errors i had with hassbian. Now it seems fixed also this about the data_template, so… i hope to have some time without headaches…
