Hi there I am getting inconsistent behavior for a templated automation that I cannot explain:
This one is working correctly
alias: Screens Power
platform: state
entity_id: input_select.screen_selector
service: script.turn_on
data_template:
entity_id: >
{% if is_state("input_select.screen_selector", "TV") %}script.tv_toggle_power
{%-elif is_state("input_select.screen_selector", "PJ") %}
script.pj_toggle_power
{%-elif is_state("input_select.screen_selector", "off") %}
script.tv_toggle_power, script.pj_toggle_power_off
{% else %}
none
{% endif %}
but when I change the automation to check for input_boolean
state
platform: state
data_template:
entity_id: >
{%-elif is_state ("input_select.screen_selector", "off") and is_state ("input_boolean.pj_power_state", "on") -%} script.pj_toggle_power_off
{%-elif (is_state ("input_select.screen_selector", "off")) and (is_state ("input_boolean.tv_power_state", "on")) -%} script.tv_toggle_power
{% else %}
none
{% endif %}
Hass throws an error for the second template but not the first one.
Both templates are working correctly in templates testing panel for all conditions, and the error hass throws is
script.tv_toggle_power is an invalid entity id for dictionary value @ data['entity_id']. Got 'script.tv_toggle_power\n\n\n\n\n\n\n# # script.tv_toggle_power, script.pj_toggle_power_off #'
The error changes depending on the state of the input select and condition … any help to figure out what is causing this error?
