Data Template for Remote Transmitter
Is there a way we could specify the Data_template for the Remote Transmitter component?
What I want to achieve is a dynamic input of the raw codes to be passed through the remote transmitter. Currently I see that the “code” is hard-coded. I was trying to check if there is data_template option to pass “code” dynamically
Working Version
    turn_on_action:
       - remote_transmitter.transmit_raw:
           code: [414,-494,368,-496,368,-496,370,-494,368,-498,368,-25192,3540,-1678,450,-1282,424,-442,396,-468,424,-440,420,-1284,398,-466,424,-442,422,-442,422,-442,422,-1284,422,-442,424,-1282,424,-1282,422,-444,398,-1308,424,-1282,422,-1284,398,-1308,420,-1284,424,-442,422,-442,422,-1284,424,-440,424,-440,398,-466,424,-442,422,-442,424,-440,400,-464,424,-442,422,-442,424,-442,424,-1282,422,-446,420,-1284,424,-440,424,-442,422,-442,422,-1282,398,-1308,424,-442,424,-440,422,-444,424,-442,422,-442,422,-444,422,-440,400,-464,424,-442,398,-466,424,-442,422,-442,424,-442,420,-444,424,-442,422,-440,424,-1284,424,-1280,424,-1284,424,-440,422,-1284,424,-442,422,-1282,422,-1282,422,-34626,3486,-1758,368,-1340,366,-496,370,-496,368,-496,370,-1336,368,-496,368,-496,370,-496,366,-496,368,-1338,370,-496,366,-1338,366,-1340,368,-496,368,-1338,366,-1338,368,-1336,370,-1338,370,-1336,368,-496,368,-496,370,-1338,368,-496,366,-498,370,-496,368,-496,370,-496,366,-498,368,-496,368,-496,370,-496,368,-496,368,-498,368,-1338,368,-496,368,-498,368,-496,366,-496,370,-1336,368,-496,368,-496,370,-494,368,-496,370,-496,368,-496,368,-496,368,-496,366,-498,370,-496,368,-496,370,-496,366,-496,368,-496,368,-496,370,-496,368,-496,366,-496,370,-496,366,-1338,366,-498,368,-1336,368,-496,368,-1336,370,-496,368,-34680,3534,-1708,370,-1338,416,-448,416,-448,418,-448,366,-1338,418,-446,368,-496,368,-496,368,-496,366,-1340,366,-498,368,-1336,418,-1288,366,-496,418,-1290,416,-1288,416,-1290,368,-1338,418,-1288,418,-448,368,-496,418,-1288,368,-498,416,-452,364,-496,418,-446,366,-498,368,-498,366,-496,370,-496,414,-448,370,-494,368,-496,418,-448,418,-446,368,-496,418,-448,368,-496,368,-496,366,-498,420,-1286,370,-496,366,-498,418,-1286,418,-448,368,-1338,416,-1288,420,-446,416,-450,416,-1246,458,-448,366,-496,418,-1286,370,-1338,418,-446,368,-496,422,-446,366,-496,418,-448,416,-448,370,-496,368,-496,366,-498,418,-446,412,-452,418,-448,366,-498,418,-448,368,-1338,368,-1338,366,-1338,370,-496,416,-448,418,-446,368,-496,416,-448,418,-450,366,-496,420,-448,414,-448,420,-446,418,-446,368,-498,368,-498,366,-496,370,-496,368,-496,370,-496,418,-448,420,-1286,418,-1288,370,-496,366,-498,370,-496,414,-448,418,-448,368,-496,370,-496,368,-496,366,-496,370,-496,366,-1340,414,-1290,370,-496,416,-448,418,-446,368,-496,368,-496,368,-496,368,-496,368,-498,416,-446,418,-448,368,-496,366,-498,416,-448,416,-446,370,-498,366,-502,414,-446,368,-1338,368,-496,368,-498,366,-498,416,-448,416,-448,366,-1340,368,-1336,370,-496,366,-498,418,-448,366,-498,418,-446,418,-446,368,-496,370,-1336,368,-496,418,-446,368,-496,366,-498,368,-498,414,-448,418,-448,366,-500,366,-496,368,-498,366,-1338,368,-498,368,-496,418,-448,368,-1338,366,-1338,366]
           carrier_frequency: 38kHz
Desired option
    turn_on_action:
      data_template:
           code: {{ variable }}
The variable option could be fed from anywhere, either through the Remote receiving component or through a MQTT from other sources
well. so far I have proceed something like this to test whether the codes actually work.
globals:
   - id: remote_code
     type: int[2]
     restore_value: no
     initial_value: "{111, -111}"
    turn_on_action:
           code: !lambda |-
              std::vector<int> vec;
              int *i = remote_code->value();
              for (int j=0; j <2; j++)
                ESP_LOGD("Test", "Print %d", *(i+j));
                vec.push_back(*(i+j));
              return id (vec);
However, I cannot see that exact code being received (I have used another ESP with Remote Receiver component ). Why is it that the “code” that I hard coded in Remote Transmitter not received the same as that of the Remote Receiver. I tried with various hard coding numbers, but the receiver never shows the exact value. I have tested this receiver with other “proper” remotes and they seem to work correctly, indicating that the remote received is working properly, so something must be wrong here with the code. Can help check and possibly point out?
[15:13:01][D][switch:021]: ‘daikinfanmode’ Turning ON.
[15:13:01][D][Test:3261]: Print 111
[15:13:01][D][Test:3261]: Print -111
[15:13:01][D][remote_transmitter:066]: Sending remote code…
[15:13:01][D][remote.raw:041]: Received Raw: 126
