Basically, my plan is to add multiple speakers (with corresponding booleans that act as the speaker’s toggle to enable/disable them). media_player.john_s_speaker will always play.
However, the other speakers (e.g. kitchen, bedroom etc) should only play if their boolean toggle is enabled.
Is it possible to format the template such that it APPENDS the additional speakers to entity_id: ?
In other words something like this,
entity_id: media_player.john_s_speaker, [ + media_player.kitchen_speaker - if boolean enabled], [+ media_player.bathroom_speaker - if boolean enabled] etc
Any help would be most appreciated in helping to achieve this. Thank you!
This always sets John’s speaker as the default speaker and then checks each input_boolean to determine if it should append another speaker.
- service: media_player.play_media
data_template:
entity_id: >-
{% set x = 'media_player.john_s_speaker' %}
{% if states('input_boolean.kitchen') == 'on' %}
{% set x = x~', media_player.kitchen_speaker' %}
{% elif states('input_boolean.bathroom') == 'on' %}
{% set x = x~', media_player.bathroom_speaker' %}
{% elif states('input_boolean.hallway') == 'on' %}
{% set x = x~', media_player.hallway_speaker' %}
{% endif %}
{{ x }}
media_content_id: http://url.com/audio.mp3
media_content_type: audio/mp3
If you have far more than 3 or 4 speakers then it may be more efficient to use a for-loop with a dictionary (listing all the input_booleans with matching speaker names). Otherwise, the method I’ve shown is simple but effective.
You’re missing the entity_id field. Also, I seem to recall that the entity_id field inside a data_template does not accept comma separated lists, it only accepts the ‘-{{}}\n’ templated lists. I never tested it myself but I remember walking someone through this exact type of template and it never worked. That could be because the user I was helping wasn’t templating it correctly though.
I’ll give this a spin and see if a comma-separated list, produced by a data_template, is accepted by entity_id.
EDIT
Tested this simple automation and confirmed it works.
- alias: 'test CSV list'
- platform: state
entity_id: input_boolean.toggler
- service: light.toggle
data_template:
entity_id: >-
{% set x = 'light.family' %}
{% set x = x~', light.kitchen' %}
{% set x = x~', light.mantle' %}
{% set x = x~', light.hallway' %}
{{ x }}
I just tested this out and noticed that only the first 2 speakers play. (From our example, it is John’s speaker and the Kitchen Speaker). The bottom 2 speakers do not play for some reason.
I swapped the speaker names round and can confirm it’s only the first 2.
It’s not a character limit issue. With all four speakers it’s only ~115 characters long.
My mistake! It’s a logic error in the template!
I need a few moments to sort it out …
Replace the existing template with this one:
{% set x = 'media_player.hanif_s_speaker' %}
{% if states('input_boolean.mum_enabled') == 'on' %}
{% set x = x~', media_player.mums_speaker' %}{% endif %}
{% if states('input_boolean.kitchen_enabled') == 'on' %}
{% set x = x~', media_player.kitchen_speaker' %}{% endif %}
{% if states('input_boolean.jane_enabled') == 'on' %}
{% set x = x~', media_player.jane_s_speaker' %}{% endif %}
{{ x }}
nice!
since I own a couple of extra media-players, I was thinking of a way to create a group dynamically with all the ‘on’ players, and have that in a template, so I could use the group in the entity_id.
Would that be possible?
I have 1 player always on, have a ‘broadcast’ group with all players, and this would be a 3d group, with selected players, made dynamically. Could be done in python I guess, but maybe we don’t need that?
I’m guessing the guy I helped did it wrong then. I always thought it worked but I gave up on the guy when he claimed it didn’t. He must have had a typo. Oh well.
Truly one of the more challenging aspects of assisting others is to second-guess the reported results in the event the suggestion was applied incorrectly. So not only predict the expected correct but also incorrect outcomes and what may have caused them. Add the fact I’m prone to making erroneous suggestions (case in point: in this very thread) and it all leads to a long session of head-scratching and confusion. Which is why it’s always helpful to have a fresh pairs of eyes available.
I’m reminded of a cartoon from my childhood where the character misreads a giant sign above a building. The first word is “Brain” but the character refers to it as “rain”. When informed of the error, he replies “The ‘B’ was so big that I didn’t see it!”
That was my original plan and it would make the code so much cleaner and easier to maintain that way. Quite refreshing knowing there’s others out there with similar needs and (think alike)
Hopefully someone could shed some light on this in the near future as to whether this is easy to achieve…
