Data template with input number for climate
I am trying to automate setting of the target temperate on my Nest via an input_number on the UI, but I get a syntax error on my automatoion.
- alias: Nest Manual Heating Control
    - platform: time_pattern
      hours: "*"
      minutes: "*"
  condition:
    condition: and
    conditions:
      - condition: time
        after: '08:20:00'
        before: '23:00:00'
      - condition: template
        value_template: >
          {{ states('sensor.nest_temperature')| float < states('input_number.min_temperature')| float }}
      - condition: state
        entity_id: group.family
        state: 'home'
    - service: climate.set_preset_mode
        entity_id: climate.nest
        preset_mode: 'none'
    - service: climate.set_temperature
      data_template:
        hvac_mode: heat
        temperature: '{{ states('input_number.max_temperature') | float }}'
Here is the error:
2021-02-21 08:58:24 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while parsing a block mapping
in "/config/automation/nest_heating_control.yaml", line 25, column 9
expected <block end>, but found '<scalar>'
in "/config/automation/nest_heating_control.yaml", line 27, column 34
Line 25 is the first line after data_template.
Don’t use the same quotes inside and outside a template.
temperature: "{{ states('input_number.max_temperature') | float }}"
It works. Thanks a lot!
