Im accessing an api to get the current liftetime value for my power meter. Works ok, but somtimes i get values that is not correct. It will sometimes return 0, or wildly inaccuate values. I get the correct value the next time i call the aip, so i can live with that, but it gives meed bad data in the statistics and the HA energy module.
I have tried to create a data_template for the data i get from the api but i just get UNKNOWN back.
Can someone help me create a data template where
there is a minimum value (lets say 5000 or not lower that the last value)
a max value (lets say 10.000, or not more than 1000 over the latest value)
else use latest value or skip value.
My api call looks like this:
- authentication: basic
username: "xxxx"
password: "xxxx"
scan_interval: 600
resource: https://smart-me.com:443/api/Devices/xxxx
- name: "Power_Meter" #this shows the meter reading - from when the meter was installed
value_template: '{{ value_json.CounterReading }}'
unit_of_measurement: "kWh"
device_class: "energy"
json_attributes:
- "ActivePower"
- "Name"
- "Serial"
- "ActivePower"
the following template will do as the words above describe (Iâm pretty sure at least as I havenât tested it):
{% if (value_json.CounterReading > states('sensor.power_meter') | float or value_json.CounterReading > 5000)
and (value_json.CounterReading < states('sensor.power_meter') | float + 1000 or value_json.CounterReading < 10000) %}
{% else %}
{{ states('sensor.power_meter')}}
{% endif %}
I havenât checked your logic just translated the words to logic.
Also Iâm assuming where you wrote â10.000â you actually meant â10000â? otherwise it wouldnât make sense at all. but if you really meant â10â you will need to modify the template.
Thanks for the help. It got me some of the way
But it seems that i cant reference the old value, {{ states(âsensor.power_meterâ)}}, it just sets to 0.
Right now i have:
value_template: >
{% set power_min = 9035 %} # I would like to change this to previos value, but then i keep getting 0
{% set power_max = power_min+100 %}
{% if (value_json.CounterReading > power_min | float) and (value_json.CounterReading < power_max | float) %}
{% else %}
{{power_min}}
{% endif %}
What I think is happening is that the template might be getting messed up from the beginning.
Assume that when you reload the integration that the âsensor.power_meterâ state is unknown until it gets initialized.
the template looks for the state (unknown) and tries to convert it to a float. but since âunknownâ isnât a number it defaults (for now) to 0.
then power_min = 0
power_max = 100
if the counter reading isnât between 0 and 100 then it defaults to the âelseâ value (power_min) which is 0.
then the problem is that no matter what the counter reading is after that the sensor.power_meter will always be 0 and so will never be able to break out of the âelseâ and so the sensor will perpetually read 0.
I think what you will need to do is to revert your rest sensor to the original template and then create a separate template sensor to filter out the erroneous values.
so like this:
username: "xxxx"
password: "xxxx"
scan_interval: 600
json_attributes:
- "ActivePower"
- "Name"
- "Serial"
- "ActivePower"
and then the template sensor (this is using the legacy style template sensor syntax):
In your suggestion would i not just use {{ value_json.CounterReading }} as the Minimal value. Then im back where i starded i think. Because if i get the invalid value from that reading, then âPower_Meter Filteredâ vill also be wrong. or am i missing something?
Filters seems like a good choice. But i would like to set the filters to compare to previous reading, so that i could say that is needs to be higher than last reading, but not more than +100.
If i set i to static values i would need to change them in the sensor settings every time the meeter reaches that level.
How did you set it up to work?
I get format errors with:
- sensor:
- platform: filter
filters:
- filter: range
lower_bound: 0
upper_bound: 10
name: "El MĂĽler stat" #the one that i use on the energy tab
unit_of_measurement: kWh
state: "{{ states('sensor.el_maler') }}"
attributes:
device_class: energy
state_class: total_increasing
Youâre mixing template sensors and a filters. You canât do that. You have to have a separate configuration for both and youâll end up with 2 entities. A filtered entity and a template entity.
