Data_template with OR condition
Hello community,
I have the following automation to play alarm in xiaomi Gateway if at least one mobile is at home (GPSLogger):
  - service: xiaomi_aqara.play_ringtone
    data_template:
      ringtone_vol: >
        {% if device_tracker.mobile1.state == 'home' || device_tracker.mobile2.state == 'home' %}
          2
        {% else %}
          10
        {% endif %}
      gw_mac: xxxxxxxxxxxxxx
      ringtone_id: 1
But this will end in:
Invalid config for [automation]: invalid template (TemplateSyntaxError: expected token ā€˜name’, got ā€˜|’) for dictionary value @ data[ā€˜action’][1][ā€˜data_template’][ā€˜ringtone_vol’]. Got None.
It seems it doesn’t like the OR condition (||), plus it doens’t recognize the ringtone_vol value (but this depends for sure from first error). Could someone help here to add OR to IF THEN? Thank you
Thank you
Lucas
Try this:
    data_template:
      ringtone_vol: >-
        {%- if states.device_tracker.mobile1.state == 'home' or states.device_tracker.mobile2.state == 'home' -%}
          2
        {%- else -%}
          10
        {%- endif -%}
      ringtone_id: 1
Thank you for reply, I’ll try it asap even if I’m suspetting the state doesn’t work or at least is not valorized with word ā€˜home’, so first I would like to try to send me a notification with device state, but also there I’m getting crazy :roll_eyes:
  - service: notify.notifiche
    data_template:
      title: "Notification"
      message: "GPS State: {{ device_tracker.mobile1.state }}"
Obliviously other Pushbullet notifications work perfect!!!
EDIT: Ah got it! I forgot ā€œstates.ā€ as per your code
your state should be states.device_tracker.mobile1.state
No way :frowning:
/home/homeassistant/.homeassistant/configuration.yaml: while parsing a block mapping
in ā€œ/home/homeassistant/.homeassistant/automations.yamlā€, line 333, column 7
expected ā€˜block end’, but found ā€˜scalar’
in ā€œ/home/homeassistant/.homeassistant/automations.yamlā€, line 336, column 11
I move the gateway volume set to a script to simplify the action, so I tried the following, but still got error:
  - service: script.turn_on
    data_template:
      entity_id: >
          script.gateway_volume_ten
        {% endif %}
probably the indentations.
Ty this instead:
    data_template:
      ringtone_vol: >-
        {%- if states.device_tracker.mobile1.state == 'home' or states.device_tracker.mobile2.state == 'home' -%}2{%- else -%}10{%- endif -%}
      ringtone_id: 1
if that still doesn’t work, try and replace 'home' with "home"
Same error… Maybe is better I found another way for my automation.
hum odd. If you leave everything the same and replace only
      ringtone_vol: >-
with
      ringtone_vol: >-
        2
does that work?
Try:
{% if 'home' in [ states.device_tracker.mobile1.state, states.device_tracker.mobile2.state ] %}
  0.02
{% else %}
  0.10
{% endif %}
I think @lolouk44’s implementation will work too using 0.02 and 0.10. The documentation for ringtone_vol says that it requires a % value which home assistant typically uses 0 to 1 (at least for media_player devices).
EDIT: It’s hard to say… the documentation points to using 8 as a value. I don’t know why @lolouk44’s automation isn’t working. Chances are my implementation won’t work either.
EDIT 2: I just checked the source code. The min is 0 the max is 100. So, i’m not sure why either @lolouk44’s implementation isn’t working.
    vol.Optional(ATTR_RINGTONE_VOL):
    vol.All(vol.Coerce(int), vol.Clamp(min=0, max=100))
Thank you for the info, I’ll start my automation from scratch and I’ll report the result back here!
Guys, I found the root cause of the error, and that’s a crazy issue. As I wrote I have 2 devices, real names assigned by HA are:
mine: device_tracker.ce051605ca46151234
And my wife’s one: device_tracker.52101ef647546529
The long number string is the devices serial number.
Well, the problem is my wife’s device (I’ve always known that wives are the problem :rofl: )
I don’t know why, but HA doesn’t like the device name. If, for example I modify it to:
device_tracker.cd52101ef647546529
HA accept the configuration and doesn’t give me any error. Obliviously the automation doesn’t work due to wrong device name.
Now, how can I solve this issue? The device name is automatically assigned by HA into know_devices.yaml :thinking:
EDIT 1:
Well, seem I solved in this way (using ā€˜ā€™ ):
{% if 'home' in [ states.device_tracker.ce051605ca46151234.state, 'statesdevice_tracker.52101ef647546529' ] %}
{% endif %}
No more error from HA, let’s see if the automation works.
EDIT 2: Nope, I’m surrendering… The quotes just report the name od device_tracker as state, so automation doesn’t work… That’s really odd…
Not sure. I can say that typically python does not like numbers as starting characters of object names. That could be your issue. Try swapping to this:
{% if 'home' in [ state('device_tracker.ce051605ca46151234'), state('statesdevice_tracker.52101ef647546529') ] %}
{% endif %}
This explain why I got the error, and you’re absolutely right about python.
To chek what’s the tracker state, I sent a notification to my phone, like:
message: "State: {{ state('statesdevice_tracker.52101ef647546529') }} "
This will result in (no notification sent):
ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: ā€˜state’ is undefined
The right code is:
message: "State: {{ states('device_tracker.52101ef647546529') }} "
And finally I got no errors and the notifiication says:
State: Home
I believe I can use the same format with IF THEN ELSE
Thank you very match to all, expecially you, @petro, who drive me to the solution!! :+1:
