polclota
(Pol Clota)
July 26, 2018, 9:33pm
1
The only way to solve it, unless anyone has a better understanding, was the one that follows but I really don’t like repeating code 3 times… there should be something like a case statement or so…shouldn’t it? Thanks in advance
t_on:
alias: t_on
sequence:
- service: switch.turn_on
data_template:
entity_id: >
{% if (states.input_select.timer_device.state=='Oven') %}
switch.sonoff_t1_b2
{% elif (states.input_select.timer_device.state=='Fan') %}
switch.sonoff06
{% elif (states.input_select.timer_device.state=='Pool') %}
switch.sonoff02
{% endif %}
t_off:
alias: t_off
sequence:
- service: switch.turn_off
data_template:
entity_id: >
switch.sonoff_t1_b2
switch.sonoff06
switch.sonoff02
{% endif %}
t_toggle:
alias: t_toggle
sequence:
- service: switch.toggle
data_template:
entity_id: >
switch.sonoff_t1_b2
switch.sonoff06
switch.sonoff02
{% endif %}
exec_timer2:
alias: Set device without timer
sequence:
- service: script.turn_on
data_template:
entity_id: >
{% if (states.input_select.on_off_toggle.state=='On') %}
script.t_on
{% elif (states.input_select.on_off_toggle.state=='Off') %}
script.t_off
{% elif (states.input_select.on_off_toggle.state=='Toggle') %}
script.t_toggle
{% endif %}
polclota
(Pol Clota)
July 27, 2018, 9:35am
3
Thanks so much. I’ll work it out and post the resulting code.
polclota
(Pol Clota)
July 27, 2018, 9:31pm
4
Solved!
Here goes the code, quite shorter :
exec_timer2:
sequence:
- service_template: >
switch.turn_on
switch.turn_off
switch.toggle
{% endif %}
data_template:
entity_id: >
switch.sonoff_t1_b2
switch.sonoff06
switch.sonoff02
{% elif (states.input_select.timer_device.state=='Beep') %}
script.beep
{% endif %}
You can make it even shorter with:
{% if is_state('input_select.on_off_toggle','Toggle') %}
switch.toggle
{% else %}
switch.turn_{{ states('input_select.on_off_toggle')|lower }}
{% endif %}
BTW, your last entity_id won’t work here. You can’t start a script with a switch service. You’d have to adjust the service_template so that if input_select.timer_device is ‘Beep’, then it calls the script.turn_on service.
petro
(Petro)
July 27, 2018, 9:55pm
7
@polclota could just swap all the services with homeassistant.turn_on, homeassistant.turn_ff, and home assistant.toggle.
EDIT: not sure how the script will behave…
polclota
(Pol Clota)
July 27, 2018, 9:59pm
8
Lovely… the shorter the better
polclota
(Pol Clota)
July 27, 2018, 10:07pm
9
I see, you’re both write, it was just for testing purposes…and indeed, it did not work.Now it works fine. Thank you all!
exec_timer2:
sequence:
homeassistant.toggle
{% else %}
homeassistant.turn_{{ states('input_select.on_off_toggle')|lower }}
{% endif %}
data_template:
entity_id: >
switch.sonoff_t1_b2
switch.sonoff06
switch.sonoff02
script.beep
{% endif %}
In general, when you’re testing an entity state, it’s better to write it this way:
is_state('input_select.timer_device', 'Oven')
Not only is it shorter, it won’t cause an error if the entity doesn’t exist yet.
polclota
(Pol Clota)
July 29, 2018, 9:09pm
11
Sure, I changed it and it works really fine! Thanks!
Next follows final code in case it might help other users.
exec_timer2:
sequence:
{% else %}
{% endif %}
data_template:
entity_id: >
{% if is_state('input_select.timer_device', 'Oven') %}
switch.sonoff_t1_b2
{% elif is_state('input_select.timer_device', 'Fan') %}
switch.sonoff06
{% elif is_state('input_select.timer_device', 'Pool') %}
switch.sonoff02
{% elif is_state('input_select.timer_device', 'Beep') %}
script.beep
{% endif %}
