Database corrupt, yet again
Hey guys,
Hope someone can help me, or maybe knows what I can do to fix it.
Im running HA in a Debian Virtualbox VM.
I keep getting database malformations every 2,3,4,5 months.
I got recorder purging at 5 days with repack.
The way I fix it now is exporting the corrupt db and .recover with
sqlite3 ./home-assistant_v2.db.corrupt ".recover" | sqlite3 ./home-assistant_v2.db_fix
I use ssh ha stop core, replace db with fixed one, and ssh ha start core.
What I really would like to know is why is it corrupting…?
These are the log messages of the malformation:
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:139
Integration: Recorder (documentation, issues)
First occurred: 04:12:05 (1 occurrences)
Last logged: 04:12:05
Error executing query: (sqlite3.DatabaseError) database disk image is malformed (Background on this error at: https://sqlalche.me/e/20/4xp6)
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/cursor.py", line 1135, in fetchall
    rows = dbapi_cursor.fetchall()
sqlite3.DatabaseError: database disk image is malformed
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 139, in session_scope
    yield session
  File "/usr/src/homeassistant/homeassistant/components/recorder/purge.py", line 88, in purge_old_data
    has_more_to_purge |= _purge_states_and_attributes_ids(
  File "/usr/src/homeassistant/homeassistant/components/recorder/purge.py", line 195, in _purge_states_and_attributes_ids
    state_ids, attributes_ids = _select_state_attributes_ids_to_purge(
  File "/usr/src/homeassistant/homeassistant/components/recorder/purge.py", line 255, in _select_state_attributes_ids_to_purge
    ).all():
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/result.py", line 1390, in all
    return self._allrows()
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/result.py", line 554, in _allrows
    rows = self._fetchall_impl()
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/result.py", line 2293, in _fetchall_impl
    return list(self.iterator)
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/loading.py", line 215, in chunks
    fetch = cursor._raw_all_rows()
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/result.py", line 546, in _raw_all_rows
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/cursor.py", line 2102, in _fetchall_impl
    return self.cursor_strategy.fetchall(self, self.cursor)
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/cursor.py", line 1139, in fetchall
    self.handle_exception(result, dbapi_cursor, e)
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/cursor.py", line 1080, in handle_exception
    result.connection._handle_dbapi_exception(
  File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 2343, in _handle_dbapi_exception
    raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
and
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:912
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed (Background on this error at: https://sqlalche.me/e/20/4xp6)
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 912, in _process_one_task_or_recover
    return task.run(self)
  File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 113, in run
    if purge.purge_old_data(
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 625, in wrapper
    return job(instance, *args, **kwargs)
    ).all():
My server its running on:
  • Intel(R) Core™ i5-4590 CPU @ 3.30GHz
  • disk: Samsung SSD 850
  • RAM 16GB
I already replaced the SSD and the RAM.
If you’re seeing it that much either you have disk issues or something operational is going on…
Assuming you are doing everything you can to ensure it’s not disk…
How are you shutting down HA. Is the machine crashing? What happens when the host drops? Do you have any power events? Those logs are great looking at the actual corruption but do you have any other issues in your log from before the dB corruption? (I’m wondering if your corruption is a symptom of something else. Rather than the cause)
I hardly ever shut down/reboot the host and when I do I do it the right way. (ACPI shutdown)
The server itself has never crashed, and no power loss or something alike.
I already replaced the SSD and the RAM so cant be that.
Ill save the entire log next time it happens as I dont have access to it anymore since restoring the DB.
Acpi shutdown skip some stuff
That’s a rather empty answer, to be honest.
As far as I know is acpi shutdown the preferred method of shutting down or rebooting a vm.
Also, would you like to specify what is being skipped…
Earlier this month I migrated from MariaDb back to sqlite, having never had any issues before, I ran into the above for the first time this morning seemingly ater a restart. I restored backups of 4 days ago where I know (!) it was working but also these proved to provide corrupt.
I am wondering now where this comes from as I doubt the db to be corrupt or the disk …
EDIT: I restart HA (only HA) each morning 01:00
Would you mind explaining these steps to a beginner? I am apparently having the same issue (see the description here) and only realized today that the symptoms are exactly the same as yours.
My setup is similar to yours, I reckon.
Well, I found my source…ME… I opened the db with dbbrowser whilst HA was still running
