I have updated my HA to 2023.2 but after the upgrade HA does a database migration which fails all the time. It’s a seperate MariaDB on my Synology where HA writes to. If I restart HA it does a migration again and after around 4 hours it fails again.
I did get something out of the logs but I can’t make sense out of it and I dont want to lose my DB which is 50GB in size. Don’t care about state history but I don’t want to lose my energy history
Logger: homeassistant.components.recorder.core
Source: components/recorder/migration.py:202
Integration: Recorder (documentation, issues)
First occurred: 11:19:39 AM (1 occurrences)
Last logged: 11:19:39 AM
Database error during schema migration
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1900, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 736, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 206, in execute
res = self._query(query)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 319, in _query
db.query(q)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/connections.py", line 254, in query
_mysql.connection.query(self, query)
MySQLdb.OperationalError: (1878, 'Temporary file write failure')
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 742, in _migrate_schema_and_setup_run
migration.migrate_schema(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 154, in migrate_schema
_apply_update(hass, engine, session_maker, new_version, current_version)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 854, in _apply_update
_create_index(session_maker, "states", "ix_states_entity_id_last_updated_ts")
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 204, in _create_index
raise_if_exception_missing_str(err, ["already exists", "duplicate"])
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 65, in raise_if_exception_missing_str
raise ex
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 202, in _create_index
index.create(connection)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/schema.py", line 4353, in create
bind._run_ddl_visitor(ddl.SchemaGenerator, self, checkfirst=checkfirst)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2211, in _run_ddl_visitor
visitorcallable(self.dialect, self, **kwargs).traverse_single(element)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/visitors.py", line 524, in traverse_single
return meth(obj, **kw)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/ddl.py", line 938, in visit_index
self.connection.execute(CreateIndex(index))
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 280, in execute
return self._execute_20(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1705, in _execute_20
return meth(self, args_10style, kwargs_10style, execution_options)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/ddl.py", line 80, in _execute_on_connection
return connection._execute_ddl(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1472, in _execute_ddl
ret = self._execute_context(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1943, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2124, in _handle_dbapi_exception
util.raise_(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/compat.py", line 211, in raise_
raise exception
db.query(q)
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (1878, 'Temporary file write failure')
[SQL: CREATE INDEX ix_states_entity_id_last_updated_ts ON states (entity_id, last_updated_ts)]
(Background on this error at: https://sqlalche.me/e/14/e3q8)
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:125
First occurred: 5:45:31 PM (1 occurrences)
Last logged: 5:45:31 PM
Error executing query: (MySQLdb.OperationalError) (1878, 'Temporary file write failure') [SQL: CREATE INDEX ix_states_entity_id_last_updated_ts ON states (entity_id, last_updated_ts)] (Background on this error at: https://sqlalche.me/e/14/e3q8)
