Hi all,
Ever since I updated to 0.95.4, I’m getting database errors multiple times per day. The errors seem to come in pairs, first a “Error executing query” and then a “Error in database connectivity.” They also always seem to happen when inserting an event for sun.sun.
I’m running Home Assistant in docker, using a mariadb database in another docker as the recorder, and my OS is Unraid. Below are the two errors:
2019-07-14 03:50:11 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (MySQLdb._exceptions.OperationalError) (2006, 'MySQL server has gone away')
[SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (%s, %s, %s, %s, %s, %s, %s)]
[parameters: ('state_changed', '{"entity_id": "sun.sun", "old_state": {"entity_id": "sun.sun", "state": "below_horizon", "attributes": {"next_dawn": "2019-07-14T12:22:22+00:00", "ne ... (958 characters truncated) ... :00", "last_updated": "2019-07-14T10:50:11.001745+00:00", "context": {"id": "4a22c311f83c4e6892fe385a10f4bc56", "parent_id": null, "user_id": null}}}', 'LOCAL', datetime.datetime(2019, 7, 14, 10, 50, 11, 1791, tzinfo=<UTC>), datetime.datetime(2019, 7, 14, 10, 50, 11, 5570), '4a22c311f83c4e6892fe385a10f4bc56', None)]
(Background on this error at: http://sqlalche.me/e/e3q8)
2019-07-14 03:50:11 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (MySQLdb._exceptions.OperationalError) (2006, 'MySQL server has gone away')
(Background on this error at: http://sqlalche.me/e/e3q8). (retrying in 3 seconds)
Let me know if you need more information. Thanks for any insight you can provide!!
