Database Files to usb hassio
Is it already possible to move the database to usb in hassio?
I got it working at hassbian but switched and cant get it to work now.
I want to give sd card a longer life!
Are you using Hassio or Hassbian? They are 2 different ways of installing HA.
You do not say, but I am inferring you are running (something) on a Raspberry Pi.
I just recently move my manyal HA installation (similar to HAssbian) to a spare laptop USB hard drive I had instead of the SD card.
They did :wink: They said they’re running Hass.io.
Yes its hassio on raspberry pi.
So you run on harddisk with raspberry. Do you use hassio?
Cant find how to do that, sounds good
I am using HASS in a venv but Hassio would work too, installed on Raspbian Lite.
I bought a USB case off Amazon for my old laptop SSD. I used Etcher to flash Raspbian Lite to the SSD. It complained about a 120 GB SD Card but it worked.
I then followed the instructions to set USB boot mode. I removed the CD Card and booted off the SSD. For Hassio, you can follow their Linux instructions to install. The actual install command needs to be a little different, though
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s -- -m raspberrypi3
https://www.raspberrypi.org/documentation/hardware/raspberrypi/bootmodes/msd.md
Thanks for this. But i only want to put database on usb, not whole setup.
I am looking into doing the same thing. I’ll let you know if I have any luck. I feel like I have read a how-to somewhere but I am having no luck finding it.
I hope you find something!
I am worried about the life of the sd card.
This one?
https://www.cribbstechnologies.com/index.php/home-assistant/moving-home-assistant-logs/
I’m heaving trouble following this instructions, The sudo command not found ?
Thank you
