Database is broken
Having trouble with my db and cannot fix it
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: SELECT statistics_short_term.metadata_id, statistics_short_term.start_ts, statistics_short_term.mean, statistics_short_term.min, statistics_short_term.max, statistics_short_term.last_reset_ts, statistics_short_term.state, statistics_short_term.sum FROM statistics_short_term JOIN (SELECT statistics_short_term.metadata_id AS metadata_id, max(statistics_short_term.start_ts) AS start_max FROM statistics_short_term WHERE statistics_short_term.metadata_id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) GROUP BY statistics_short_term.metadata_id) AS anon_1 ON statistics_short_term.metadata_id = anon_1.metadata_id AND statistics_short_term.start_ts = anon_1.start_max] [parameters: (5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 26, 27, 28, 29, 30, 34, 35, 36, 37, 38, 39, 40, 159, 123, 124, 129, 130, 135, 136, 91, 94, 98, 100, 106, 108, 110, 85, 87, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 117, 118, 140, 152)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1964, in _exec_single_context
    self.dialect.do_execute(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 748, in do_execute
    cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 123, in session_scope
    yield session
  File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 1971, in get_latest_short_term_statistics
    stats = cast(Sequence[Row], execute_stmt_lambda_element(session, stmt))
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 207, in execute_stmt_lambda_element
    executed = session.execute(stmt)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 2229, in execute
    return self._execute_internal(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 2124, in _execute_internal
    result: Result[Any] = compile_state_cls.orm_execute_statement(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/context.py", line 253, in orm_execute_statement
    result = conn.execute(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1414, in execute
    return meth(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/lambdas.py", line 600, in _execute_on_connection
    return connection._execute_clauseelement(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1638, in _execute_clauseelement
    ret = self._execute_context(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1842, in _execute_context
    return self._exec_single_context(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1983, in _exec_single_context
    self._handle_dbapi_exception(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2326, in _handle_dbapi_exception
    raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
i have tried this:
sqlite3 ./home-assistant_v2.db ".recover" | sqlite3 ./home-assistant_v2.db.fix
mv ./home-assistant_v2.db ./home-assistant_v2.db.broken
mv ./home-assistant_v2.db.fix ./home-assistant_v2.db
and
sqlite3 ./home-assistant_v2.db ".dump" | sqlite3 ./home-assistant_v2.db.fix
but with this commands nothing happens.
I hope someone can help me to recover my 6gb big database - i hope not to lose over 1 year of data
