HA has two categories of data (not counting metadata): state and long-term statistics. State data is kept for x days as specified by purge_keep_days on the recorder integration, which defaults to 10. Long-term statistics (which includes energy data) is kept forever.
So unless you currently have purge_keep_days set to 730 (2 years), you won’t lose anything. And if you haven’t specified purge_keep_days, setting it to 30 will likely increase your database by a factor of nearly 3.
@michaelblight that clears a bit.
Long Term data isn’t affected bij the purge_keep_days setting, so if i decrease the purge_keep_days to 4 or 5 days that won’t affect the energy data.
next step is to exclude some entities and find a way to copy the energy data from maria db to influxdb
