2018-12-04 19:35:19 WARNING (Recorder) [homeassistant.components.recorder.migration] Database requires upgrade. Schema version: 7
I get the above warning in my log file. What am I supposed to do here? I am currently on version 82.1.
Are you trying to upgrade Hassio? Are you using Owntracks? I had this issue when trying to upgrade. There are breaking changes in owntracks: https://github.com/home-assistant/home-assistant/issues/18809#issuecomment-443134375
Once I made the owntracks changes, then performed the hassio ugprade the database warning is gone
I commented out the OwnTracks stuff in my config file and then upgraded. The upgrade worked and I no longer have the database upgrade warning. Thanks.
Cool, just ensure you change the owntracks config so it will continue to work
Thanks! Having troubles upgrading as well. Will try
