The goal is to only allow automation to run if after the date and time of an date-time helper. I’m thinking it’s only evaluating the time portion and not the date and time??
Here is the value of the helper
Here is the trace.
Here is the trace.
Try using a Template condition instead placing the following in the “value template” field:
{{ now() >= states('input_datetime.cam_lower_rear_delay_time') | as_datetime | as_local }}
Thank You, So the GUI Time condition only evaluate time, If so is this intended?
For now, the Time condition only evaluates the time component of a datetime object… there is a warning about this in the docs (Conditions - Home Assistant)
The now time is ~ 14:40 the trigger time is after 16:25. It shouldn’t trigger. 2:40 pm is before 4:25 pm. Result should be false.
OP’s question is because it’s14:40 on the 28th, and the datetime helper is 16:25 on the 27th…
Ah, of course didn’t see the warning… Nice and big too…
Thank you for your help.
