Hello, this is the first time I publish desperate, i’m could not get it to work, the correct date format from a sensor.file that extracts the date from a json string, this is my configuration.yaml:
sensor 4:
- platform: file
file_path: Batch.json
value_template: "{{ value_json.Depuracion_Rollbacks.Date_debut.Fecha | timestamp_custom('%d/%m/%Y') }}"
sensor 5:
- platform: file
value_template: >
{% set date = states('sensor.batch_file_inicio') %}
{{ as_timestamp(strptime(date, '%d/%m/%Y')) | timestamp_custom('%d/%m/%Y') }}
{% if date == states('sensor.date') %} Batch 1
{% else %} Batch 2
{% endif %}
I have used other methods, but still have not succeeded. What is the most practical way to solve it?
The result of the above code gives me always: Batch 2
123
(Taras)
June 2, 2020, 11:26pm
2
On my system, sensor.date reports in ISO format: YYYY-MM-DD
Does sensor.batch_file_inicio report its date in the same format?
Note:
Have you defined sensor.date in configuration.yaml?
Thanks Taras. I’m not sure if sensor.batch_file_inicio have any date format.
this is a small screenshot.
123
(Taras)
June 3, 2020, 1:42pm
4
The screenshot explains why your template always reports Batch 2.
This line in the template can never be true
because the date format of sensor.batch_file_inicio is DD/MM/YY which is not the same as the date format of sensor.date which is YYYY-MM-DD.
You will have convert one of the two dates to a common format before comparing them.
Try this:
sensor 5:
- platform: file
value_template: >
{% set today = now().timestamp() | timestamp_custom('%d/%m/%y') %}
{% if states('sensor.batch_file_inicio') == today %} Batch 1
{% else %} Batch 2
{% endif %}
Taras that was great, now i have a batch 1. You make this very simple.
Many thanks.
