Is there a possibility to correctly format a date on a Lovelace card?
DD / MM / YYYY for example?
{{ now().strftime("%d-%m-%Y,%H:%M") }}
Sure, but in a card ?
entities:
- entity: input_boolean.presence_marie
- entity: input_datetime.next_marie_start
- entity: input_datetime.next_marie_stop
show_header_toggle: false
theme: teal
title: Planification
type: entities
Creating yet another set of sensors is one way. Maybe there is another.
I wanted to uso that but the switch between the part “now()” for another entity that has the exame same format, doesn’t retrieve any result.
{{ ENTITY.strftime("%d-%m-%Y,%H:%M") }}
ENTITY = a fixed time and date, with the exact format as now()
Would be glad if i could show the dates in the format as shown by Canaletto. But I cant - here I always see dates like this:
Which obviously is quite frustrating during the first 12 days of each month.
Canalettos view is actually an international standard for the format which does NOT cover the format xx/xx/yyyy
I also want my date format shown in the Lovelace card as dd/mm/yyyy. I also want to use the “date picker” to select the date.
