Date format template works in developer tools but gives error in config
Hi I'm trying to get at waste sensor state date from 2020-8-4 to: Tuesday 04 August 2020
This works in devoper tools template:
>  *{{strptime(states("sensor.non_recyclable_waste_pickup"), '%Y-%m-%d').strftime('%A %d %B %Y')}}*
result: Tuesday 04 August 2020 :+1:
So that works and gives wanted result.
Then the I configured this:
*- platform: template*
*  sensors:*
*    grijzebak_waste:*
*      friendly_name: 'Grijzebak'*
*      value_template: " {{strptime(states("sensor.non_recyclable_waste_pickup"), '%Y-%m-%d').strftime('%A %d %B %Y')}}"*
This gives an error.
*Configuration invalidCHECK CONFIGURATION*
> *Error loading /config/configuration.yaml: while parsing a block mapping in "/config/sensor.yaml", line 12, column 7 expected <block end>, but found '<scalar>' in "/config/sensor.yaml", line 13, column 44*
Can anybody help me out?
You have nested double quotes in your value_template line.
value_template: "{{strptime(states("sensor.non_recyclable_waste_pickup"), '%Y-%m-%d').strftime('%A %d %B %Y')}}"
Turn those into single quotes:
value_template: "{{strptime(states('sensor.non_recyclable_waste_pickup'), '%Y-%m-%d').strftime('%A %d %B %Y')}}"
Please format your posts properly :slight_smile:.
Thanks Troon, That helped! You are great! :slight_smile:
