Datetime template help
I have an alarm clock setup that uses input_datetime.manual_alarm as an input. I have a HAdashboard setup that I would like to show the datetime in a user friendly format. i.e. “9:30 PM”
The datetime is setup without using a date in configuration.yaml
input_datetime:
  manual_alarm:
    name: Manual Alarm Time
    has_date: false
    has_time: true
If I put
{{ states.input_datetime.manual_alarm.state}}
in the template developer tool I get
06:35:00
So I was thinking my template should be something like this…
{{as_timestamp(strptime(states.input_datetime.manual_alarm.state, ‘%H:%M:%S’)) | timestamp_custom(‘%-I:%M %p’)}}
but I get “Unknown error rendering template”.
I believe the clue to its failure is provided by this example:
{{ strptime("06:35:00", '%H:%M:%S') }}
Result:
1900-01-01 06:35:00
Look at the year. It presents a problem for as_timestamp to convert it to a timestamp (Unix time). It’s too old.
According to the Wikipedia page for Unix time:
On systems where Unix time is stored as a signed 32-bit number, the largest value that can be recorded is 2147483647 (231 − 1), which is 03:14:07 Tuesday, 19 January 2038 UTC. The following second, the clock will wrap around to negative 2147483648 (−231), which is 20:45:52 Friday, 13 December 1901 UTC. This is referred to as the Year 2038 problem .
Similarly there’s a lower date limit and your example predates it.
If you put this into the Template Editor:
{{ as_timestamp(strptime("1902 06:35:00", '%Y %H:%M:%S')) }}
You get:
-2145875100.0
If you change the year to 1901 it results in Unknown error rendering template.
Try this:
{{states.input_datetime.manual_alarm.attributes.timestamp | timestamp_custom('%-I:%M %p', false)}}
EDIT
Corrected typo in the template.
Any ideas of other ways to template this to be in a more friendly format?
Did you try what I suggested?
I am so sorry. The email notification missed off the last line. I didn’t see the possible solution.
It was almost correct. The following works. Thank you for your help. I am sorry I missed it.
{{states.input_datetime.manual_alarm.attributes.timestamp | timestamp_custom(’%-I:%M %p’, false)}}
Sorry about that. For my tests I used an input_datetime with a completely different name. At the last second I replaced its name with yours … and made a copy-paste error (and needlessly included .state.)!
Glad to hear it ultimately worked out for you (and I’ve corrected my original post).
