I’m new with HA so the question might be silly or very easily solved.
I’m looking for how to set temperatures every evening at 10.00 to 2-3 degrees celsicus lower than what they are at 0959. And in the early morning (0400 maybe) raise the temperature 2-3 degrees again.
Another thing, where does this code go, is it typically in automation.yaml or something?
Thanks for helping out, really dig Home Assistant so far ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
Hi again,
i’m on my way to something… But I struggle a bit.
How can I call a group of thermostats, say group.thermostats, and adjust temperature with this code snip? It’s working for one entity called climate.kitchen. But if I use group.thermostats instead of climate.kitchen it doesn’t work. Do I have to iterate the group and set temperature some how?
temperature: "{{(state_attr('climate.kitchen' , 'temperature')|round(0)) - 2 }}"
