Hi all,
I am in New Zealand and it is winter time yet HA still shows the time as GMT +13. It should be GMT +12 and a cant find a way to fix this.
Any ideas?
F
Hi all,
Any ideas?
F
You don’t describe how you run ha. Bare metal, docker, haos.
What does the machine say the time is?
Also have you restarted ha since daylight savings ended. There is a bug where the time doesn’t sort itself around the change over at daylight savings (both directions)
Sorry, I’m new on this platform.
Im running HAOS superviser on a VM and it performs well.
The issue is that under System - General the only time zone option available is GMT + 13 (Auckland). It should be GMT +12 (Auckland) for this time of year, ie Daylight saving time is not active.
My HA instance has had numerous updates and restarts since this issue became apparent to me and I have read all the posts about restart required etc but this issue is higher level it seems.
