Hi folks!
I recently purchase these DazzBling lights for my new place: DazzBling 98ft Outdoor String Lights
I’m having issues picking the colour of these lights from the Home Assistant interface.
Whenever I select a colour, they just go green. Some colour picks give a brighter green, some give a more dim green. In the Tuya app, it works correctly and I can set all different colours.
I assumed it was an HSV vs RGB thing, so logged onto the Tuya IoT portal to check - and device debugs showed that the colour I was attempting to set from home assistant was correct - but the lights themselves were just green.
I’ve tried to search the forums/web with not a whole lot of luck.
I’d assume it was some form of integration issue, but where should I start?
Thanks!
