I got this error when updating.
I have the recorder configured in a external MariaDB DB.
Log Details (ERROR)
Logger: homeassistant.components.recorder
Source: components/recorder/migration.py:110
Integration: Recorder ([documentation](https://www.home-assistant.io/integrations/recorder), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+recorder%22))
First occurred: 8:11:16 AM (1 occurrences)
Last logged: 8:11:16 AM
Database error during schema migration
Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1808, in _execute_context self.dialect.do_execute( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 732, in do_execute cursor.execute(statement, parameters) File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 206, in execute res = self._query(query) File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 319, in _query db.query(q) File "/usr/local/lib/python3.9/site-packages/MySQLdb/connections.py", line 254, in query _mysql.connection.query(self, query) MySQLdb._exceptions.OperationalError: (2013, 'Lost connection to MySQL server during query') The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 992, in _migrate_schema_and_setup_run migration.migrate_schema(self, current_version) File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 79, in migrate_schema _apply_update(instance, new_version, current_version) File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 648, in _apply_update _create_index(instance, "states", "ix_states_attributes_id") File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 112, in _create_index raise_if_exception_missing_str(err, ["already exists", "duplicate"]) File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 44, in raise_if_exception_missing_str raise ex File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 110, in _create_index index.create(connection) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/schema.py", line 4287, in create bind._run_ddl_visitor(ddl.SchemaGenerator, self, checkfirst=checkfirst) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2119, in _run_ddl_visitor visitorcallable(self.dialect, self, **kwargs).traverse_single(element) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/visitors.py", line 524, in traverse_single return meth(obj, **kw) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/ddl.py", line 936, in visit_index self.connection.execute(CreateIndex(index)) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1295, in execute return meth(self, multiparams, params, _EMPTY_EXECUTION_OPTS) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/ddl.py", line 80, in _execute_on_connection return connection._execute_ddl( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1387, in _execute_ddl ret = self._execute_context( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1851, in _execute_context self._handle_dbapi_exception( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2032, in _handle_dbapi_exception util.raise_( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 207, in raise_ raise exception File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1808, in _execute_context self.dialect.do_execute( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 732, in do_execute cursor.execute(statement, parameters) File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 206, in execute res = self._query(query) File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 319, in _query db.query(q) File "/usr/local/lib/python3.9/site-packages/MySQLdb/connections.py", line 254, in query _mysql.connection.query(self, query) sqlalchemy.exc.OperationalError: (MySQLdb._exceptions.OperationalError) (2013, 'Lost connection to MySQL server during query') [SQL: CREATE INDEX ix_states_attributes_id ON states (attributes_id)] (Background on this error at: https://sqlalche.me/e/14/e3q8)
