Yeah tried that and tried in an another browser that I’ve not used with HA before.
None of the core DT files seem to have changed so don’t see much point in replacing them, it’s weird.
Josh
Josh
There you go Dwains.
And yes i’m on 0.110… and yes maybe other stuff is broken but since I started using on 0.110 I can’t really figure it out
Ah the browser_mod is totally broken… at least on my end.
Thanks.
Decided to poke around at this today, very impressive stuff @dwains. The way in which icons are loaded was updated in 0.110. A quick work around is to use thomasloven’s font-awesome component. There looks to be other issues (I’m not familiar enough with this to be sure what is missing and what is not) but that one was quite obvious and may help some folks.
Yep Dwains Theme, it’s more then a theme tho, is very nice indeed, just waiting for it to be fully compatible with 0.110.
Working hard on Dwains Theme v1.4 with a lot of new awesome features. Hope to release it start of June.
Tks u very much
Dude this should go on the cookbook page - VERY well laid out! thanks for sharing
Who do we need to speak to?
Awesome news Dwain! Thanks for all your hard work!!
Officially this is the addon repository with dwains theme addons from the community. I hope @jimpower will upload (PR) his addons also here in the end GitHub - dwainscheeren/dwains-dashboard-addons: Dwains Dashboard Community Addons
@dwains , there’s an addon there which was made by Nick Papenborg that shows the power usage, I wonder if you know which template he used to create the average power sensor, average daily and costs. I have my own but they are all “Total”.
Can you help? or maybe reaching Nick, he should be here somewhere
Thanks.
I need to look into it, but Nick is on my Home Assistant Addicts Discord server Like many others who are using my theme. Home Assistant Addicts
@dwains I am hesitant to do so at this stage as they are really made for my screen size and I have paid absolutely no heed to scaling for smaller screens at all. I am an RF Engineer specialising in IoT so coding is def not my day job so some collaberation from the community or yourself to help include them in upcoming releases might help with portibility as this is your thing I’m just dabbling
i use switch not light… mode so all of them are entities…
I’m up for that
Good afternoon guys, recently i just started having a little of issue with my theme setup. So far i haven’t been able to pin point my issue. My issue is with the menu bar where everything just displayed all over and for the life of me, i cannot seem to be able to fix yet. Maybe you guys could help…
Try clearing your cache and refresh it does this to me alot as I make alot of changes. If you hit f5 normally is enough though
Thank you for your fast reply sir; but I tried that multiple time for the past 3 days. That was the trick for me, but now it does not work.
@dwains is it possible to mod the flexbox-card to allow different classes? I’m trying to build something where I want one small column and the remainder, but it requires the use of different classes to control the flexbox widths
something like this:
<div class="row">
<div class="col-xs-12 col-sm-3 col-md-2 col-lg-1">(content-1)</div>
<div class="col-xs-12 col-sm-9 col-md-10 col-lg-11">(content-2)</div>
</div>
Yeah you can use item_classes
on the card itself so content-1 and content-2 that’s already possible with current version
