If I understated your question, the answer is Yes. I still have my former dashboard AND the Dwain’s Theme dashboard. Once I get it tweaked to my satisfaction, I’m going to make Dwain’s my default.
But I don’t know enough about HA to say if you can specify different default dashboards per client device, but that’s more of a general HA / Lovelace question I believe.
I’m trying to work around the limitation of the the theme not supporting switches by using devices instead.
But if I have more than one ‘device’ in a room, do I need to create a device group in order for them to be displayed correctly? I seem to be getting inconsistent results with the approaches I’ve tried.
As an aside, I’ve been doing the same for some key sensors (like my basement flood detector or ‘care in garage’ presence detector), which results in icons that just yield non-fatal errors when ‘clicked’. I will need to figure out if there is a better way to handle status-only sensors.
I’m wanting to set it as the default for all users, even ones I haven’t created yet. I think it is a limitation in home assistant that you cant set a system wide default
Hi, excellent theme. Just one question. The black header background on the starting page does not have rounded corners at the bottom. What am I doing wrong? =)
EDIT: Found it and edited myself in the 01.hompage.yaml.
Changed border radius to these values instead. =)
border-radius: 0px 0px 20px 20px; (Was only 0 before. Now the bottom corners are rounded.)
Hi, thank you. Yes some screenshots are from the first version which had rounded bottom corners on the homepage. I removed this in a future update to make it more consistent with the header on all other pages. (Yeah I need to update those screenshots in the topic start post xD)
Just wondering if someone might know the answer to this. Just started using this theme and loving it so far. Its working great on desktop but currently on android (in browser and in app) its just freezing with a blank screen or partially loading and freezing when trying to access the UI.
The only error I am getting is for a brief moment “custom element doesn’t exist: dwains-flexbox-card”
First of all I want to tank you @dwains for this incredible theme.
I tried a lot of custom cards and other UI posted here in the community.
This one is the only one very close to the “Plug and Play” solution. I love it.
Here my question:
Is there a way to use my devices as buttons (like the lights)?
I don’t like too much this screen:
