DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Thx so much
Dwains dashboard probably best HA dashboard, keep the good work, you are awesome
Can confirm updating works also with 2021.4.1 it is working fine. :slight_smile:
Thanks for the great work!
Hi and thank you for great work and effort! :ok_hand:
Is there a way to set the preferred action on click of an entity in a rooms page?
Specifically; I have made two scripts for opening and closing of the garagedoor which I have added in rooms.yaml as page entities:
    page_entities:
      columns: 1
      entities:
        - entity: script.door_garage_garagedoor_open
        - entity: script.door_garage_garagedoor_close
They end up in the room just as I expected - however, as the default click action for scripts seems to be to open up the script properties rather then just run it, my idea fell pretty flat. :wink:
It might be that it’s very simple to solve, at least that’s what I hope for. :slight_smile:
Thanks!
Where do you change translation of some words, where in config can i change
You can add a own room addon to the room and tweak the button.yaml file to a button which does what you want :slight_smile:
Integrations -> Dwains Dashboard -> Options -> Language
Ah, interesting - I’ll look into that. Thanks!
//m
Take a look here on how to make it https://github.com/dwainscheeren/dwains-lovelace-dashboard/discussions/267
Works perfect with HACS install, awesome! thanks:)
Dear Dwain
Very thanks for your efforts.i have successfully installed this Dashboard.
But I have no more idea how to configure it.means how to add switch,light,cards etc .
And I am the beginner in HA .
I believe you should help me
I found it
I meant translation of some words - camera , temperature etc
Thx
Use customize.yaml to customize you own entity names if that is what you mean.
No, no
I meant in dashboard : rooms , devices, temperature etc.
But i did find it, in translation, where are languages, a transferred danish to croatian, thx a lot
Awesome :slight_smile: glad you all like it. Some other people installed 2.0.2 and got it succes fully working? Please let me know.
Fully working
Your work is awesome
Working perfectly!
Thank you!
Glad you all got it working :slight_smile: I already started to work on DD 3.0 only need to look to combine it with my normal job and can’t spend too much time on it without a lot of donations :stuck_out_tongue:
For me its working fine! I took the way over HACS, that made is very easy.
i am truly beginner with homeassistant … I try to install Dwain dashboard but gives me an error (Config flow could not be loaded)
so how can i handle it
thanks for ur greatly dashboard
Worked like a charm doing it that way, thank you @dwains !! :raised_hands:
