Worked like a charm doing it that way, thank you @dwains !!
Not sure, just copy the zip extract it and install it it are only 3 steps.
I can also confirm that these steps worked - thanks @dwains !
After upgrading from 2014.3.x to 2021.4.3, I got errors in the core logs and Dwain’s Dashboard showed an unknown error dialog. Overwriting the existing DT files with 2.0.2 fixed both issues.
I still have one error in my logs which I am trying to run down (see below), but it otherwise seems to work fine.
ERROR (MainThread) [frontend.js.latest.202104073] http://192.168.#.###:8123/dwains_dashboard/js/dwains-dashboard.js:90:11007 Uncaught TypeError: Cannot read property 'config' of undefined
You can ignore that error, its a small (bug) I need to fix in upcoming version.
@dwains The dashboard looks great! I see people are installing it via HACS, how is that done? I don’t see it in the repositories.
First of all, what is this great! should be in hassio by default!
Crazy question. can i also use a camera on a page?
Hey Guys!
I have a few problems and i hope someone could help me.
As you can see on the sceenshots, i have a few covers in a room, which only support open or close, but i’m always getting an undefined % state, anyone knows why and how to disable?
Second thing the covers (“Rollladen” in my picture) look a bit weird, because they are not centralized in the card.
And the “Wiedergabegeärte” (Media-Players) are too long, you can see some overlapping there.
Do you know, how to solve these problems?
Cheers
Its a bug its fixed in next version. The translation is also too long, t he person who made the translation needs to change that
I’m waiting on hacs default for a long time Adds new integration [dwainscheeren/dwains-lovelace-dashboard] by dwainscheeren · Pull Request #698 · hacs/default · GitHub
Yes camera on a room page for example see: dwains-dashboard-addons/rooms/camera at for-dd-2.0 · dwainscheeren/dwains-dashboard-addons · GitHub
Add it manual in hacs by repo url.
Ok thanks for that info. then i hope, the next version will be released soon xD
Greetings
I did it like this but I think I’m doing something wrong but what
- name: Gijs
icon: fas:bed
temperature: sensor.kamer_gijs_temperature
humidity: sensor.kamer_gijs_humidity
door: binary_sensor.0xbc33acfffe34c2a9_contact
addons:
- name: Camera
path: 'dwains-dashboard/addons/rooms/garage/camera/page.yaml'
button_path: 'dwains-dashboard/addons/rooms/garage/camera/button.yaml'
entity: camera.blueiris_kamer_gijs
I can’t help you without an error or you tell what exactly is not working.
Does someone know, if i can add a new tab here?
I know i can add something new to the navbar with the more_pages file, but am i also able to add a new tab besides rooms and devices?
Greetings
Thanks for the reply. What’s the link to the repo? I tried to add your GitHub as the repo but it won’t add to HACS. I assume I’m using the wrong link.
That is not possible.
I also cant get this installed.
I’m on Home Assistant version - core-2021.4.5.
Any chance it’s not compatible? I’m not a total noob and have tried a few different ways but unfortunately can’t add the integration despite installing through HACS.
Update: Weird but after like 10 restarts from working on other items it has now showed up. Cant wait to start playing around.
It should work, latest version 2.0.2 and version 2021.4.*. Try to install it manually its just copying 1 zip. Dwains Lovelace Dashboard | An auto generating Home Assistant Lovelace UI dashboard for desktop, tablet and mobile by Dwains for desktop, tablet, mobile
I just edited my post above but it randomly started showing up. Looks awesome by the way, I’ll be donating if it is something I decide to use after playing around.
