I just publish a Dietrich/Diematic (Modbus) to MQTT Interface.
Here it is:
My project is now using Home Assistant as front end
Regards
Benoit
Here it is:
Regards
Benoit
Hello Benoit
Very good job. as i wrote on github i am trying to adapt your script to communicate with sofath heat pump. i thought something broke in the code but by losing power yesterday my usr adapter broke.
would there be a lot of work on your code to use the rs485 modbus to usb adapter or the rs485 hat for rapsberry pi?
in my opinion it would be a better solution - in one housing I enclose the rpi and rs485 hat and mount it inside the device.
I’m pretty weak at python.
you would be able to work together to modify it a little. today I will try to write you which registers should be read/write from the sofath (dedetrich) caliane heat pump (direct evaporation) I have a diematic 4 controller.
the reading values for the alarms are different. in the heat pump value 65535 = no alarm.
because i ordered a new rs485 - tcpip adapter and i dont know when it will come. I was forced to run a preview of the heat pump with this script found on github - it works reasonably well except that it throws a lot of communication errors - well, I can run the bimaster mode. there was no error problem in your script.
Oh My God!
I’ve just found your message now and it looks awesome!
I have an “old” De Dietrich MC 25 LP with a Diematic 3 control board and I thought I was out of luck to integrate it with Home Assistant…
Thanks to your message, it seems that it’s almost possible!
I’ve read your instructions on GitHub, it seems quite complex for a newbie like me, but, I would be happy to try!
Can it helps you to have more Home Assistant user? And if yes, how can we help?
Hello.
Sorry to not have answered earlier, I didn’t receive notification and was busy : I’ve add the MQTT discovery feature for Hassio. So you don’t have to write MQTT message definition, just to build the cards you want.
Benoit
To answer @Wrafal , yes some significant coding have to be done if you user an USB RS485 or RS485 hat for Raspberry PI: you need to detect the beginning and end of each modbus frame. This job is already done in the rs485 - tcpip adapter.
Benoit
Hello.
Thanks for you great work I have a MC25MI and I look for trying to connect it to hassio. I am a beginner and I would like to know if it is possible to run the script in the same Raspeberry Pi where I have my HA and under Home Assistant OS? Can you help me with this part of the setup?
Regards
Yes it is possible, I dit it with HA but with the Install Home Assistant Core .
The Diematic to MQTT interface needs only python 3.8 or more and few libraries.
I don’t know HA OS but if the line command python3 --version give a result it should be possible…
Benoit
Hello!
Is there anyway to get Energy Cost (kwH) using modbus? In specification:
is at T1/TELECOMMANDE2, but querying register I’m getting nothing.
Hey there! I’m currently having a completely different question. Does anyone advise how the dedietrich heatpump Is controlled by indoor unit? 2 terminals (S1 And S2) marked from diagram but if I trace they Are fused ending up on L1 And N of the control/supply board. I do miss the whole control indoor board anyway.
Could anyone help?
I have 2 questions :
Could it be possible to add it directly as an add-on (like Zwvea2MQTT/Zigbee2Mqtt etc… )?thank’s!
Unfortunately the answer it’s no to both questions:
But I’m open to github Pull Request
Regards
Hello @BenoitS,
Would it be complicated to adapt your program to work with Diematic Delta ? I’ll be happy to help, but have no idea about the feasibility (I have a din connector but read somewhere the modbus communication was different from your model).
Thanks!
Hi again,
Could you please also share tour YAML paramteres for your cards?
Hello
Did any one use the Home Assistant Python Scripts integration (I gues it will not work because of missing Python imports support) or the HACS custom integration pyscript?
I would like to run the everything (if possible) within Home Assistant with additional integrations like MQTT.
Looking forward to find someone to exchange experiences.
Hello @matiou ,
it’s feasible but not easy.
Have a look here
Difficult for me due to lack of time and no access to a Diematic Delta regulator.
Benoit
cards:
- type: entities
entities:
- entity: sensor.ext_temp
- entity: sensor.power
- entity: sensor.alarm
- entity: select.zone_a_mode
icon: mdi:water-boiler
- entity: sensor.zone_a_mode
- entity: sensor.zone_a_temp
- entity: binary_sensor.zone_a_pump
icon: mdi:pump
- entity: sensor.pump_power
- entity: select.hot_water_mode
secondary_info: last-updated
- entity: sensor.hot_water_mode
- entity: sensor.hot_water_temp
- entity: binary_sensor.hot_water_pump
title: Chauffage
show_header_toggle: true
state_color: true
- type: entities
entities:
- entity: number.zone_a_temp_day
icon: mdi:thermometer-plus
- entity: number.zone_a_temp_night
- entity: number.zone_a_temp_antiice
- entity: number.hot_water_temp_day
icon: mdi:water-plus
- entity: number.hot_water_temp_night
- entity: switch.heater_datetime_set
title: Réglages Chauffage
show_header_toggle: false
- type: entities
entities:
- entity: sensor.heater_datetime
icon: mdi:clock-time-eight-outline
- entity: sensor.type
icon: mdi:cpu-32-bit
- entity: sensor.ctrl
- entity: sensor.zone_b_temp
icon: mdi:pump
- entity: binary_sensor.zone_b_pump
icon: mdi:pump
icon: mdi:pump
- entity: binary_sensor.burner_status
icon: mdi:fire-circle
- entity: sensor.fan_speed
icon: mdi:fan
- entity: sensor.ionization_current
- entity: sensor.boiler_temp
- entity: sensor.target_temp
- entity: sensor.return_temp
- entity: sensor.smoke_temp
- entity: sensor.water_pressure
- entity: sensor.alarm_id
icon: mdi:water-boiler-alert
title: ParamĂŞtres Chauffage
state_color: true
Hi Benoit
You’ve done a fantastic job and I’m trying to use it to monitor my old MC25BIC from de dietrich in HA ios : Home Assistant 2022.12.6, Supervisor 2022.11.2, Operating System 9.4 with an interface
USR-TCP232-306
I’ve followed your procedure in Python script deployment and copied all files in directory /share/mosquitto/boiler. In terminal, if I browse to that directory, I can launch the script with python3 Diematic32MQTT.py and get data on log.out file. Example for 2 lines
2022-12-17 12:33:49,581 - main - INFO - Publish :home/heater/boiler/ext/temp 8.2
2022-12-17 12:33:49,582 - main - INFO - Publish :home/heater/boiler/temp 43.3
Hourra, my MC25Bic is alive !!
Then I’ve set 2 people in HA “core-mosquitto” and “boiler” and set this conf in mosquitto broker :
logins:
Unfortunately I did not manage to get mqqt in HA to discover the boiler and in fact I do not know how to get HA to read the file Diematic32MQTT.conf.
Thanks a lot for your help
I’ve too remarks
which may help you to understand what happen
I’ve no knowledge to generate an HA module, and unfortunately no time to get it. The file Diematic32MQTT.conf is not written to be read by HA, only by the Diematic32MQTT software.
only basic connection to mqtt brooker is available, without login/password, without certificate neither cyphering. It could be quite easy to implement, but not done. Always a problem of time.
Do you use any of these security features?
Benoit
Thanks for your answer.
1- Ok understand. I can run the Diematic32MQTT software in terminal in HA and it works. Could find a way to have it launched at HA startup?
2- I’ve installed MQTT just to read this diematic32mqtt so I’ll adapt
Merci encore
to run it as a service, have a look here :
It works under raspbian, with HA OS, I don’t know.
Benoit
