Hi all,
I am searching a lot about how to get the De Dietrich Smart TC Thermostat connected to HA.
I couldn’t find any tip.
Can someone help on this?
Thanks a lot!
Hi all,
Thanks a lot!
I am interested in this solution too.
Let me know when you have an answer.
I am looking for a solution too…
Julien
I couldn’t find any solution so far. Really disappointing.
Got info from BDR and they say that will be soon compatible with Alexa and Google Home. But not sure when this soon will be XD
I’m using remeha_home hacs integration (GitHub - msvisser/remeha_home: Remeha Home integration for Home Assistant)
it’s the same API. its working like a charm.
Thanks a lot! I’ll test it!
TNX for info. It is working just greatXD
Do you have issue that you cant connect on thermostat with Remeha or De Dietrich smart APP?
If using home assistant with remeha app, I frequenlty loose the connection to the GW from mobile app.
Thanks for the tip. We bought this thermostat about 1,5 year ago, and ii had this working for a few months with HA, But the owner of the project got a take down request. And i specifically bought this because it would work with HA… with this it works again!.. Thank you so much!
No issues with the application of the vendor as well… though I probably will abandon it… maybe just to adjust a programming setting… but now i do not have to use that application anymore.
