I gave both of the above a try (resetting/etc…). When I go to “Add Node” in the z-wave panel I see this:
2019-05-24 19:59:33.353 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x14, 0x65
2019-05-24 19:59:33.353 Detail, Notification: ControllerCommand - Starting
2019-05-24 19:59:33.355 Detail,
2019-05-24 19:59:33.355 Info, contrlr, Sending (Command) message (Callback ID=0x14, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x14, 0x65
2019-05-24 19:59:33.359 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x14, 0x01, 0x00, 0x00, 0xa7
2019-05-24 19:59:33.359 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-05-24 19:59:33.359 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2019-05-24 19:59:33.360 Detail, Node001, Expected callbackId was received
2019-05-24 19:59:33.360 Detail, Node001, Expected reply was received
2019-05-24 19:59:33.360 Detail, Node001, Message transaction complete
2019-05-24 19:59:33.360 Detail, contrlr, Removing current message
2019-05-24 19:59:33.360 Detail, Notification: ControllerCommand - Waiting
2019-05-24 19:59:33.361 Info, WriteNextMsg Controller nothing to do
And then nothing else. The other switch now seems to be screwing up now too. I must’ve goof’d the network up somehow. Is there any way I can reset the z-wave integration completely? (like delete the entire integration and all entities (because I know there are some .yaml files/etc… that store the entities)
