Deadbold Lock Status Sensor
:locked_with_key: DIY Lock Status Sensor
(Kwikset + Aeotec + Home Assistant + HomeKit)
Goal
I wanted lock state visibility (locked/unlocked) in Home Assistant and Apple Home, without installing a true smart lock.
  • Household preference: :cross_mark: no remotely unlockable lock
  • Solution: :white_check_mark: read-only lock state using internal hardware
:brain: Concept
Use:
  • Existing mechanical limit switch inside the lock
  • Feed it into a Z-Wave sensor with dry contact input
  • Expose as a lock entity in Home Assistant β†’ HomeKit
No motor control. No unlocking. Just state.
:toolbox: Hardware Used
  • Kwikset keypad deadbolt (existing)
  • Aeotec Door/Window Sensor 7 Pro (ZWA012)
    • Key feature: dry contact input terminals
:locked_with_key: Original Lock
Exterior:
Interior:
:wrench: Step 1 β€” Gut the Lock
I opened the lock and exposed:
  • Motor + gearbox
  • Large plastic gear
  • Built-in microswitch (limit switch)
Key insight:
The gear already presses a microswitch when the lock is in the locked position.
No need to add a separate sensor.
:electric_plug: Step 2 β€” Use the Existing Microswitch
The switch behaves like a dry contact:
  • Closed when locked
  • Open when unlocked
I verified this with a multimeter, then soldered wires to the switch terminals.
:link: Step 3 β€” Wire to Aeotec Sensor
Wiring:
Microswitch β†’ Aeotec Terminal 2 (Digital)
Microswitch β†’ Aeotec Terminal 3 (VCC reference)
No connection to ground (Terminal 1) required.
:gear: Step 4 β€” Configure Aeotec Sensor
In Home Assistant Z-Wave configuration:
  • Parameter 1: External terminal inputs
  • Parameter 2: Switch mode
This disables the internal magnet sensor and uses your external switch.
:battery: Step 5 β€” Power Decision
Initially considered reusing the lock’s 4Γ—AA battery pack, but rejected due to:
  • Voltage mismatch (6V vs ~3V required)
  • Need for regulator
  • Added complexity
Final choice: Use Aeotec’s native 1/2 AA battery.
:brick: Step 6 β€” Fit Everything Inside
  • Removed original batteries
  • Used a Dremel to cut battery compartment
  • Mounted Aeotec sensor inside lock housing
:warning: Mechanical Tuning
Problem:
  • Switch worked when disassembled
  • Failed intermittently when fully assembled
Solution:
  • Slightly bent the microswitch lever arm
Result: Reliable actuation in final installed state.
:house: Step 7 β€” Home Assistant Template Lock
lock:
    name: "Back Door Lock"
    unique_id: back_door_lock
    value_template: >
      {{ is_state('binary_sensor.back_door_lock_binary_sensor', 'on') }}
:red_apple: Step 8 β€” HomeKit Integration
  • Mode: Accessory
  • Include domain: lock
After adding, the lock appears in Apple Home.
:bullseye: Final Result
  • :locked_with_key: Lock shows Locked / Unlocked in Apple Home
  • :prohibited: Cannot be unlocked remotely
  • :high_voltage: Fully local Z-Wave
  • :battery: Long battery life
