I hooked up keyboard and tried to login, but id and password might be wrong.
pi, homeassistant…everything was wrong.
What is default id and password?
One more question, with official image for Rpi, it uses docker, right?
If I want to use another instance of rpi, how can I do it?
I am beginner of docker…so it is very complicated…
I’ll defer to others, but it depends on what additional containers you want to run on the same Pi.
There are quite a number of containers that you can add to HA from the menu which are referred to as add-ons. The community catalog is at https://addons.community . There are additional catalogs you can add as well. If an existing add-on doesn’t meet your needs or you want/need additional control you can install your own OS with Docker enabled.
