Debian 10 HA docker You are running an unsupported installation. Learn More
logs supervisor:
20-09-01 09:42:14 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-09-01 09:42:14 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-01 09:42:14 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-09-01 09:42:14 INFO (MainThread) [supervisor.host.services] Update service information
20-09-01 09:42:14 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-09-01 09:42:14 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-09-01 09:42:14 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-09-01 09:42:14 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
Failed to load cookie file from cookie: No such file or directory
20-09-01 09:42:14 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-09-01 09:42:14 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-09-01 09:42:14 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-09-01 09:42:14 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 9
20-09-01 09:42:14 INFO (MainThread) [supervisor.plugins.dns] Restart CoreDNS plugin
20-09-01 09:42:14 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-09-01 09:42:14 INFO (SyncWorker_0) [supervisor.docker.interface] Restart homeassistant/amd64-hassio-dns
20-09-01 09:42:19 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-09-01 09:42:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-audio with version 17
20-09-01 09:42:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-cli with version 25
20-09-01 09:42:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-multicast with version 3
20-09-01 09:42:19 INFO (MainThread) [supervisor.plugins.multicast] Restart Multicast plugin
20-09-01 09:42:19 INFO (SyncWorker_0) [supervisor.docker.interface] Restart homeassistant/amd64-hassio-multicast
20-09-01 09:42:23 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-01 09:42:23 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.114.4
20-09-01 09:42:23 INFO (MainThread) [supervisor.hassos] No Home Assistant Operating System found
20-09-01 09:42:23 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-09-01 09:42:23 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-09-01 09:42:23 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 66 new - 0 remove
20-09-01 09:42:23 INFO (MainThread) [supervisor.addons] Found 4 installed add-ons
20-09-01 09:42:23 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 5.0.0
20-09-01 09:42:23 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-ssh with version 8.6.0
20-09-01 09:42:23 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to hassioaddons/glances-amd64 with version 0.8.0
20-09-01 09:42:23 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to hassioaddons/home-panel-amd64 with version 1.8.1
20-09-01 09:42:23 INFO (MainThread) [supervisor.snapshots] Found 8 snapshot files
20-09-01 09:42:23 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-09-01 09:42:23 INFO (MainThread) [supervisor.ingress] Load 4 ingress session
20-09-01 09:42:24 INFO (MainThread) [supervisor.misc.secrets] Load Home Assistant secrets: 1
20-09-01 09:42:24 INFO (MainThread) [__main__] Run Supervisor
20-09-01 09:42:24 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-09-01 09:42:24 CRITICAL (MainThread) [supervisor.core] System running in a unsupported environment!
20-09-01 09:42:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' start 0 add-ons
20-09-01 09:42:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' start 0 add-ons
20-09-01 09:42:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' start 2 add-ons
20-09-01 09:42:24 INFO (SyncWorker_4) [supervisor.docker.interface] Clean addon_core_ssh application
20-09-01 09:42:25 INFO (SyncWorker_4) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 8.6.0
20-09-01 09:42:25 WARNING (SyncWorker_0) [supervisor.docker.addon] Glances run with disabled protected mode!
20-09-01 09:42:25 INFO (SyncWorker_0) [supervisor.docker.interface] Clean addon_a0d7b954_glances application
20-09-01 09:42:26 INFO (SyncWorker_0) [supervisor.docker.addon] Start Docker add-on hassioaddons/glances-amd64 with version 0.8.0
20-09-01 09:42:30 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_glances
20-09-01 09:42:31 INFO (SyncWorker_4) [supervisor.docker.interface] Start homeassistant
20-09-01 09:42:31 INFO (MainThread) [supervisor.homeassistant] Wait until Home Assistant is ready
20-09-01 09:42:46 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-09-01 09:42:52 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-09-01 09:42:52 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' start 2 add-ons
20-09-01 09:42:52 INFO (SyncWorker_0) [supervisor.docker.interface] Clean addon_core_configurator application
20-09-01 09:42:53 INFO (SyncWorker_0) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-configurator with version 5.0.0
20-09-01 09:42:53 INFO (SyncWorker_4) [supervisor.docker.interface] Clean addon_a0d7b954_home-panel application
20-09-01 09:42:54 INFO (SyncWorker_4) [supervisor.docker.addon] Start Docker add-on hassioaddons/home-panel-amd64 with version 1.8.1
20-09-01 09:42:59 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_home-panel
20-09-01 09:42:59 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-09-01 09:42:59 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-09-01 09:42:59 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-09-01 09:42:59 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-01 09:42:59 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-09-01 09:43:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-01 09:43:00 INFO (MainThread) [supervisor.host.services] Update service information
20-09-01 09:43:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-09-01 09:43:00 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-09-01 09:43:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-09-01 09:43:00 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-09-01 09:43:59 INFO (SyncWorker_1) [supervisor.docker.interface] Update image hassioaddons/glances-amd64:0.8.0 to hassioaddons/glances-amd64:0.9.0
20-09-01 09:43:59 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image hassioaddons/glances-amd64 tag 0.9.0.
20-09-01 09:44:09 INFO (SyncWorker_1) [supervisor.docker.interface] Stop addon_a0d7b954_glances application
20-09-01 09:44:14 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_a0d7b954_glances application
20-09-01 09:44:15 INFO (SyncWorker_4) [supervisor.docker.interface] Cleanup images: ['hassioaddons/glances-amd64:0.8.0']
20-09-01 09:44:15 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_glances' successfully updated
20-09-01 09:44:15 WARNING (SyncWorker_3) [supervisor.docker.addon] Glances run with disabled protected mode!
20-09-01 09:44:16 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on hassioaddons/glances-amd64 with version 0.9.0
20-09-01 09:44:20 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_glances
20-09-01 09:45:31 INFO (MainThread) [supervisor.snapshots] Full-Snapshot 6afb83f6 start
20-09-01 09:45:31 INFO (MainThread) [supervisor.snapshots] Snapshot 6afb83f6 store Add-ons
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_configurator
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_configurator
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_ssh
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_ssh
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on a0d7b954_home-panel
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon a0d7b954_home-panel
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on a0d7b954_glances
20-09-01 09:45:31 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon a0d7b954_glances
20-09-01 09:45:31 INFO (MainThread) [supervisor.snapshots] Snapshot 6afb83f6 store folders
20-09-01 09:45:31 INFO (SyncWorker_4) [supervisor.snapshots.snapshot] Snapshot folder addons/local
20-09-01 09:45:31 INFO (SyncWorker_4) [supervisor.snapshots.snapshot] Snapshot folder addons/local done
20-09-01 09:45:31 INFO (SyncWorker_6) [supervisor.snapshots.snapshot] Snapshot folder share
20-09-01 09:45:31 INFO (SyncWorker_6) [supervisor.snapshots.snapshot] Snapshot folder share done
20-09-01 09:45:31 INFO (SyncWorker_1) [supervisor.snapshots.snapshot] Snapshot folder homeassistant
20-09-01 09:45:37 INFO (SyncWorker_1) [supervisor.snapshots.snapshot] Snapshot folder homeassistant done
20-09-01 09:45:37 INFO (SyncWorker_0) [supervisor.snapshots.snapshot] Snapshot folder ssl
20-09-01 09:45:37 INFO (SyncWorker_0) [supervisor.snapshots.snapshot] Snapshot folder ssl done
20-09-01 09:45:37 INFO (MainThread) [supervisor.snapshots] Full-Snapshot 6afb83f6 done
The system:
arch x86_64
chassis desktop
dev false
docker true
docker_version 19.03.12
hassio true
host_os Debian GNU/Linux 10 (buster)
installation_type Home Assistant Supervised
os_name Linux
os_version 4.19.0-10-amd64
python_version 3.8.3
supervisor 235
version 0.114.4
virtualenv false
Lovelace
dashboards 1
mode storage
resources 0
views 3
Using Debian 10 and following a strict set of guidelines available HERE will give you a supported installation of Home Assistant Supervised. If you choose at anytime to install additional software to the Debian operating system, your installation will become officially unsupported. Community support via the forums is always available however.
Installing Home Assistant Supervised using Debian 12
Are all these conditions true
Additional supported conditions
This installation method can easily be broken if one manages the operating system incorrectly. Therefore, the following additional conditions apply:
  • The operating system is dedicated to running Home Assistant Supervised.
  • All system dependencies are installed according to the manual.
  • No additional software, outside of the Home Assistant ecosystem, is installed.
  • Docker needs to be correctly configured to use overlayfs2 storage and journald as the logging driver.
  • NetworkManager is installed and enabled in systemd.
  1. Yes. It works ok. But after last update it have the error.
  2. Yes. I installed it use the manual.
  3. Yes.
cat /etc/docker/daemon.json
“storage-driver”: “overlay2”
“log-driver”: “journald”
  1. yes
I installed Debian 10 64Bit version of Raspbain and HA not showing this to me anymore :slight_smile:
https://downloads.raspberrypi.org/raspios_arm64/images/raspios_arm64-2020-05-28/2020-05-27-raspios-buster-arm64.zip
if all the prereqs are true i would suggest logging a github issue to find out why its says unsupported
although it only a warning, doesnt really stop you using HA
Supported Operating System, System dependencies and versions
Docker CE (Community Edition) is the only supported containerization method for Home Assistant Supervised. We only support FHS 3.0 on the host file system.
  • Docker CE >= 19.03
  • Systemd >= 239
  • NetworkManager >= 1.18.0
  • Avahi >= 0.7
  • AppArmor == 2.13.x (built into the kernel)
  • Debian Linux Debian 10 aka Buster (no derivatives)
Only the above-listed version of Debian Linux is supported for running this installation method. When a new major version of Debian is released, the previous major version is dropped, with a deprecation time of 4 months. An exception to this rule occurs if the new version does not meet the requirements of the Supervisor.
dpkg --status Systemd
Package: systemd
Status: install ok installed
Priority: important
Section: admin
Installed-Size: 13484
Architecture: amd64
Multi-Arch: foreign
Version: 241-7~deb10u4
Replaces: udev (<< 228-5)
Depends: libacl1 (>= 2.2.23), libapparmor1 (>= 2.9.0-3+exp2), libaudit1 (>= 1:2.2.1), libcap2 (>= 1:2.10), libcryptsetup12 (>= 2:1.6.0), libgnutls30 (>= 3.6.6), libgpg-error0 (>= 1.14), libidn11 (>= 1.13), libip4tc0 (>= 1.6.0+snapshot20161117), libkmod2 (>= 5~), liblz4-1 (>= 0.0~r130), libmount1 (>= 2.30), libpam0g (>= 0.99.7.1), libseccomp2 (>= 2.3.1), libsystemd0 (= 241-7~deb10u4), util-linux (>= 2.27.1), mount (>= 2.26), adduser
dpkg --status docker-ce
Package: docker-ce
Priority: optional
Section: admin
Installed-Size: 104064
Architecture: amd64
Version: 5:19.03.12~3-0~debian-buster
Replaces: docker-engine
Depends: docker-ce-cli, containerd.io (>= 1.2.2-3), iptables, libseccomp2 (>= 2.3.0), libc6 (>= 2.3.2), libdevmapper1.02.1 (>= 2:1.02.97), libsystemd0
dpkg --status network-manager
Package: network-manager
Priority: optional
Section: net
Installed-Size: 11584
Architecture: amd64
Version: 1.14.6-2+deb10u1
Depends: libaudit1 (>= 1:2.2.1), libbluetooth3 (>= 4.91), libc6 (>= 2.26), libcurl3-gnutls (>= 7.16.3), libglib2.0-0 (>= 2.43.2), libgnutls30 (>= 3.6.5), libjansson4 (>= 2.0.1), libmm-glib0 (>= 1.0.0), libndp0 (>= 1.2), libnewt0.52 (>= 0.52.20), libnm0 (= 1.14.6-2+deb10u1), libpolkit-agent-1-0 (>= 0.99), libpolkit-gobject-1-0 (>= 0.104), libpsl5 (>= 0.13.0), libreadline7 (>= 6.0), libselinux1 (>= 1.32), libsystemd0 (>= 221), libteamdctl0 (>= 1.9), libudev1 (>= 183), libuuid1 (>= 2.16), lsb-base, wpasupplicant, dbus, udev, adduser, libpam-systemd, policykit-1
dpkg --status avahi-daemon
Package: avahi-daemon
Priority: optional
Section: net
Installed-Size: 278
Architecture: amd64
Multi-Arch: foreign
Source: avahi (0.7-4)
Version: 0.7-4+b1
Depends: libavahi-common3 (>= 0.6.16), libavahi-core7 (>= 0.6.24), libc6 (>= 2.27), libcap2 (>= 1:2.10), libdaemon0 (>= 0.14), libdbus-1-3 (>= 1.9.14), libexpat1 (>= 2.0.1), adduser, dbus (>= 0.60), lsb-base (>= 3.0-6), bind9-host | host
dpkg --status apparmor
Package: apparmor
Priority: optional
Section: admin
Installed-Size: 1833
Architecture: amd64
Version: 2.13.2-10
Replaces: fcitx-data (<< 1:4.2.9.1-1ubuntu2)
Depends: debconf, lsb-base, debconf (>= 0.5) | debconf-2.0, python3:any, libc6 (>= 2.17)
screenfetch
     _,met$$$$$gg.           user@nuc
  ,g$$$$$$$$$$$$$$$P.        OS: Debian 10 buster
,g$$P""       """Y$$.".      Kernel: x86_64 Linux 4.19.0-10-amd64
,$$P’ $$$. Uptime: 1h 53m ',$$P ,ggs. $$b: Packages: 1762
d$$' ,$P"' . $$$ Shell: bash $$P d$' , $$P CPU: Intel Pentium N3700 @ 4x 2.4GHz [48.0°C] $$: $$. - ,d$$' GPU: $$\; Y$b._ _,d$P' RAM: 1283MiB / 3869MiB Y$$. ."Y$$$$P"' $$b “-.__
Y$$ Y$$.
$$b. Y$$b.
"Y$b._ “””"
Time to log a github issue then
just noticed your network manager is lower version
Yes, but it is default into debian 10.
Well the requirements need that, so it probably why. i would suggest confirming with them on github
Have you tried upgrading it to confirm?
I have this in /etc/docker/daemon.json :
  "log-driver": "journald",
  "storage-driver": "overlay2"
I had the same “unsupported” message on a current Debian 10 supervised install.
Rerun the install script on top of the existing HA install from
fixed the problem.
Bingo! Big THX!
After the command i rebooted the PC.
hi HBK … I have the same message too … do I need to reinstall HA or Debian?
No reinstall needed, just run as root (according to the linkabove) and reboot after:
curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s
it worked but with your command not the one in the link
