Debian 10 Install, Hard Disk Space Used Up
Well this is getting a bit silly i install Debian 10 with home assistant on to a 120GB ssd drive because of the famous “Unsupported” message. And its been a a few weeks and my 120GB drive is now full. And it wont boot. So I got a bigger ssd drive 500GB and again its starting to fill up again quite fast.
HA 0.114.4
And HA logs are normal the HA DB is about 720mb
Screenshot 2020-09-10 at 17.46.19
Any help as to why this is happening?
Did you specify the correct docker logging driver ?
Do you mean this.
Screenshot 2020-09-10 at 17.58.53
Then Yes
Looks a lot like this problem:
Thanks I have read it and it seems that it should not happen on the Debian install with the journald logging. The guy was using Ubuntu.
