I have been running HA Supervised on Debian for the last 6 years, and recently noted that disk space is being consumed … once I delete some files, after a few hours space is consumed back to 100% (my disk is just 128GB - and the logs are taking 57GB).
The following files are taking the most space and their content seems to be related to DNS entries:
NUC01:/var/log$ ls -lh | grep G
total 57G
-rw-r----- 1 root adm 5.7G Nov 1 10:32 daemon.log
-rw-r----- 1 root adm 2.4G Oct 27 00:01 daemon.log.1
-rw-r----- 1 root adm 5.5G Nov 1 10:32 messages
-rw-r----- 1 root adm 2.9G Oct 27 00:01 messages.1
-rw-r----- 1 root adm 16G Nov 1 10:32 syslog
-rw-r----- 1 root adm 7.8G Oct 27 00:01 syslog.1
-rw-r----- 1 root adm 11G Nov 1 10:32 user.log
-rw-r----- 1 root adm 5.4G Oct 27 00:01 user.log.1
Some examples below:
daemon.log
Nov 1 10:34:37 NUC01 dockerd[563]: time="2024-11-01T10:34:37.909731031+01:00" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:172.30.32.3:52580" dns-server="udp:192.168.1.212:53" error="read udp 172.30.32.3:52580->192.168.1.212:53: i/o timeout" question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" spanID=ed77a78ae2150cd4 traceID=42dda78def5ad05b021c00783e8013e5
Nov 1 10:34:37 NUC01 dockerd[563]: time="2024-11-01T10:34:37.909734594+01:00" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:172.30.32.3:34070" dns-server="udp:192.168.1.212:53" error="read udp 172.30.32.3:34070->192.168.1.212:53: i/o timeout" question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" spanID=32f123d83452a7e2 traceID=ed241790a05f2490f8242bf6fac69e4e
Nov 1 10:34:38 NUC01 systemd[1]: run-docker-runtime\x2drunc-moby-e10d5a13318fb18de8bee99006c1aa8ac206d184c9d6ec73fe053417244a1048-runc.EtaW6q.mount: Succeeded.
Nov 1 10:34:38 NUC01 systemd[435380]: run-docker-runtime\x2drunc-moby-e10d5a13318fb18de8bee99006c1aa8ac206d184c9d6ec73fe053417244a1048-runc.EtaW6q.mount: Succeeded.
Nov 1 10:34:38 NUC01 dockerd[563]: time="2024-11-01T10:34:38.061193916+01:00" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:172.30.32.3:55409" dns-server="udp:192.168.1.212:53" error="read udp 172.30.32.3:55409->192.168.1.212:53: i/o timeout" question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" spanID=ec6b9e4f605b4e36 traceID=476fd06dc6322fa55a66c2f694efdf00
Nov 1 10:34:38 NUC01 dockerd[563]: time="2024-11-01T10:34:38.118968202+01:00" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:172.30.32.3:32807" dns-server="udp:192.168.1.212:53" error="read udp 172.30.32.3:32807->192.168.1.212:53: i/o timeout" question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" spanID=cf63d4787cc74897 traceID=330d79266800c338bdab78bb84a9ae73
messages
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:55729 - 28537 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.02342137s
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:55804 - 56183 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.02428919s
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:56035 - 41660 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.028600628s
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:35667 - 39464 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.029865481s
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:37624 - 58619 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.031240252s
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:52801 - 6503 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.031748813s
Nov 1 10:36:59 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:55729 - 32469 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.023528745s
syslog
Nov 1 10:37:53 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:52810 - 23666 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.0419139s
Nov 1 10:37:53 NUC01 dockerd[563]: time="2024-11-01T10:37:53.563484280+01:00" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:172.30.32.3:41072" dns-server="udp:192.168.1.212:53" error="read udp 172.30.32.3:41072->192.168.1.212:53: i/o timeout" question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" spanID=7cdaa48970bbe5c8 traceID=388e511366c7f2ba685817fab5db7016
Nov 1 10:37:53 NUC01 addon_a0d7b954_adguard[563]: 2024/11/01 10:37:53.567514 ERROR response received addr=172.30.32.3:53 proto=udp status="exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:41296->172.30.32.3:53: i/o timeout"
Nov 1 10:37:53 NUC01 addon_a0d7b954_adguard[563]: 2024/11/01 10:37:53.567564 [error] dnsproxy: exchange failed upstream=172.30.32.3:53 question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" duration=2.001450339s err="exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:41296->172.30.32.3:53: i/o timeout"
Nov 1 10:37:53 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:55936 - 43021 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.028424062s
Nov 1 10:37:53 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:40956 - 33286 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.030096658s
user.log
Nov 1 10:38:35 NUC01 addon_a0d7b954_adguard[563]: 2024/11/01 10:38:35.214712 [error] dnsproxy: exchange failed upstream=172.30.32.3:53 question=";2.0.17.172.in-addr.arpa.\tIN\t PTR" duration=2.002223844s err="exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:54524->172.30.32.3:53: i/o timeout"
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:47935 - 9724 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.024956814s
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:59298 - 65460 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.026179857s
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:41416 - 19696 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.031213401s
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:57566 - 31512 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.03220952s
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:43366 - 27079 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.037723336s
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 172.30.32.1:41002 - 41232 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 2.038625289s
Nov 1 10:38:35 NUC01 hassio_dns[563]: [INFO] 127.0.0.1:40942 - 26192 "PTR IN 2.0.17.172.in-addr.arpa. udp 52 true 2048" NXDOMAIN qr,rd,ra 41 0.039483721s
Also in the configuration.yaml I have the following:
logger:
default: error
logs:
homeassistant.core: warning
homeassistant.components.influxdb: warning
homeassistant.components.rest: warning
I think this started recently because the hard disk went full this week, if it has been going like this before most probably I would have noticed.
Any ideas how to go around this?
