akash1
March 2, 2023, 3:17pm
1
Hi Everyone,
HA Noob here.
Issue: My HA instance often loses connectivity with the following symptoms:
I don’t know what’s the issue. But the only way out is to power cycle.
Then everything works, for a while.
It might be something unique to my setup, so I’ll try to describe it best I can:
Network
RPi4 is my unify controller
I have a couple of unify switches & AP’s
Everything else on the network has absolutely no problems connecting
HA
Running off a Raspberry Pi 3 A+
Booting off an SSD
Connected over Ethernet (Pi >> Unify Switch >> Another Unify Switch >> Router)
Other Info
I use a Conbee II stick
A separate Raspberry Pi 3 A+ is running DeConz/Phosconn
HA instance is connected this this IP address (“add integration” >> “deconz”)
Important to note, I have absolutely no other connectivity problems on my home network.
Uploading (an) image that should illustrate the problem.
Consolidating 3 things into 1, as I am a new user
As per the router, homeassistant is disconnected.
But the ping works just fine.
And I can’t access HA via the browser. (both IP address and homeassistant.local:8153 don’t work)
Thanks!
akash1
March 2, 2023, 4:03pm
3
Just power cycled the R Pi to get back in the system.
I don’t see much here unfortunately. Just this -:
And now I can’t connect with the system again. Estd. uptime is ~5mins.
odwide
March 2, 2023, 5:15pm
4
For network troubleshooting a layered strategy is often successful. How does the router probe the HA IP? When the problem is happening check:
What happens if you simply reconnect the Ethernet cable?
Does telnetting into 8123 on the HA IP work? This indicates whether a TCP handshake is still possible.
Simplify the setup. Try connecting the RPi more directly.
Login to the RPi locally and check the status of listening ports.
akash1
March 3, 2023, 2:20am
5
Thanks @odwide
1 & 3 are simple enough. I’ll try those.
Does this mean using something like Putty?
Should SSH be enabled on HA? Or is that by default?
How would I do this? Connect monitor via HDMI?
Thank you
akash1
March 3, 2023, 2:50am
6
Hi @tom_l
Is there a way to get older logs?
Given that I have to power cycle things, I just don’t see older entries - at least in the frontend.
tom_l
March 3, 2023, 2:58am
7
Yes, there’s a file that is saved from before the last restart in your config directory, home-assistant.log.1
note the “.1
tylas13
(Tylas13)
March 3, 2023, 3:48am
8
To add to odwide’s comment also check your wires and connections. Use a different Ethernet cable that is trusted on a more direct port on the switch.
I had this issue a year ago when one wire came loose behind my patch panel, it wasn’t until I connected directly did I find the intermittent issue.
akash1
March 3, 2023, 8:23am
9
Thanks,
1/
Direct connection - Connected direct to router. Still not working.
2/
Based on @tom_l 's advice, I tried to install “File Editor” to get into the config directory. Which didn’t work. Just timed out. No error. System is still up, so here are the logs if you can make something of this
Right after I got this screenshot, I clicked the button to refresh the logs.
I’m back to “Connection lost. Reconnecting”
tom_l
March 3, 2023, 9:55am
10
Your power supply is not sufficient.
akash1
March 3, 2023, 10:04am
11
I did see that a few minutes back, so I re-tried with another PSU.
Requirements needed:
5 V/2.5 A DC
I was using a 5V, 2.1 A PSU.
I’ve now subbed it for a an Anker Powerport that gives 5V, 4A on the USB port. (max output of 2.4A per port). Also changed the microUSB cable for good measure.
Let’s see
tom_l
March 3, 2023, 10:19am
12
The pi 3A+ recommended power supply is 5V at 2.5A. That’s with an SD card. You have an SSD so it will be even more. You probably need a minimum of 3A.
akash1
March 3, 2023, 10:26am
13
Noted… thanks @tom_l
Even after the “upgraded” PSU, I’m still getting the low power message in the logs
This is my current PSU
Based on what you’re saying, this is not enough. Given the cap of 2.4A per port.
I’ll upgrade and then check back.
Thank you
odwide
March 3, 2023, 10:57am
14
No need to enable SSH. Telnet will simply do a TCP handshake with the HA web server, indicating whether the connection is healthy enough to go beyond a simple ping. On Windows you can enable the Telnet Client feature or use Powershell.
telnet <HA IP> 8123
A blank command prompt means that the handshake succeeds. Otherwise you’ll get an error.
akash1
March 7, 2023, 2:38pm
15
So, I moved over to an SD Card. As @tom_l pointed out, the SSD has its own power requirements (which is 1A).
It is a lot better now. The system is mostly stable, but still goes down once a day. I think it might still be a power supply issue?
Perhaps HA needs the best quality power possible? That’s the theory I’m going with. I have ordered the official power supply.
Does anyone have any suggestions on what other power supplies I could try? (Something to power both Pi + SSD)
PS: I tried the below check
Got a blank screen. So I suppose that means the connection is healthy?
But it doesn’t matter, as homeassistant.local:8123 does not open.
odwide
March 7, 2023, 4:06pm
16
If telnet works most likely it’s not a network issue.
akash1
March 11, 2023, 6:16am
17
True, I don’t think it is a network issue at all.
I’ve been searching online and have found other threads of people with power issues.
It’s looking like the power requirements of HA & Pi3 A+ are quite stringent.
I think I’ll need to find a good 5.1V, 2.5A PSU. And likely higher that 2.5A.
That said, I would really like to look at the logs just before a crash. How do that I get to that? I haven’t found any simple guide (yet).
garethjr
(Gareth Rees)
June 3, 2024, 4:52pm
18
Is there any chance you’re with Virgin Media?
I’m on Pi4 with microSD and at some point in the past it just started dropping off the network, despite a new better Ethernet cable being purchased. I’ve since switched to Wi-Fi and it’s not dropped off yet. tempts fate
Gareth
