About 2 weeks ago I had 2 updates available, one for Home Assistant Core (2023.6.3) and one for the Ring-MQTT addon (can’t remember the version but I’m pretty sure it ended in .3). As usual I said to update them, but what would happen is that it would say it was installing for a very long time (multiple minutes) then a box in the lower left would appear and say “Connection Lost. Reconnecting…” for several more minutes and then it would show that the update was unavailable
. (I’m a new forum user so can only upload one screenshot, but I have screenshots of the previous 2 states as well if needed.) After a time the update page would refresh and show the updates still needed to be installed. This went on for several days and I tried restarting Home Assistant and even the entire device a couple times. At some point, and I’m not sure when because none of the updates ever said it completed successfully, both items stopped saying there were updates and it appears that they’re both the newest versions as far as I can tell. However, since this started happening, Home Assistant will periodically hang, and I think it’s even restarting at some point, though I’m not experienced enough to say for certain. Also, trying to look at the Ring-MQTT addon’s settings will hang indefinitely. This is running a RasPi 3 using the HASSOS image and up until this, had been running fine for many months. I had recently installed the Ring-MQTT addon, but that was at least a couple weeks before this all started happening.I’m extremely green when it comes to Home Assistant so I’m not entirely sure where to start to try to figure out what might be causing the problem, much less how to go about trying to fix it. What tools or utilities should I start with to gather data that might highlight what might be causing a problem. I don’t have a whole lot of configuration in this yet, so I guess a last resort would be to just wipe and start fresh, but I’d like to avoid that and learn how to troubleshoot so when this does become my default smart home controller, I know how to try and fix it.
