Debugging Home Assistant through an IDE
I need some help debugging Home Assistant through an IDE. Any help/resource would be much appreciable.
As of now I use PyCharm CE IDE , and for running HASS i am using Linux Environment, and I do not see a way to debug my custom components or automations etc, through the linux console.
Is there a way we can debug through an IDE ?
I am looking for a detailed answer on this, so that I can get started.
I know there is an addon for Hassio that displays the home assistant log on a web page. If you are running just Home Assistant it can likely be added too.
Are you running Hassio or Home Assistant / Hassbian?
