Is it possible to debug inspect set breakpoints etc in some way?
You probably can although I haven’t tried it myself. When I need to do this, I run the AD app through the debugger in vscode on a local instance of AD. Feel free to try it out and let us know the outcome.
@proggie I am trying to do exactly that but without success so far.
What I did:
Installed locally appdaemon (no docker or venv, direct install via pip)
stopped production appdaemon docker (add-on)
started local appdaemon (connecting to my ha)
I can see from the logs that appdaemon local install is alive and well.
I tried to debug the hallo world app in vscode but an error is issued:
/usr/local/bin/python3 /Users/editeduser/appdaemon/apps/hello.py
(base) editeduser@Air-di-editeduser appdaemon % /usr/local/bin/python3 /User
File "/Users/editeduser/appdaemon/apps/hello.py", line 1, in <module>
import appdaemon.plugins.hass.hassapi as hass
ModuleNotFoundError: No module named 'appdaemon'
btw the error makes also sense to me : how do I make VS Code “aware” of the running environment of appdaemon? (i.e. of appdaemon modules location etc)
I tried to attach to the local executing appdaemon process via it’s processId but no success
TX
Maybe just try import hass
although my setup is a bit different. I do use a venv with the dev branch but not installed with pip and I develop my applications using the import adbase
method. You’ll also want to make sure the launch.json configuration is setup to properly run the appdaemon module. Here is an example.
// Use IntelliSense to learn about possible attributes.
// Hover to view descriptions of existing attributes.
// For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
"version": "0.2.0",
"configurations": [
"name": "Python: Module",
"type": "python",
"request": "launch",
"module": "appdaemon",
"args": [
"-c",
"c:/users/justin/projects/appdaemon_dev/conf",
"-D",
"INFO"
