I’m trying to get the Zigbee Integration working using a Nortek HUSBZB-1 on a new Home Assistant install. Using:
- Home Assistant 2021.5.5
- Docker version 20.10.8
- docker-compose version 1.29.2
- Ubuntu 20.04.3 LTS
My docker compose looks like:
version: '2'
services:
home-assistant:
container_name: home-assistant
image: homeassistant/home-assistant:latest
network_mode: "host"
restart: unless-stopped
privileged: true
volumes:
- /srv/home-automation/hass-config:/config
- /etc/localtime:/etc/localtime:ro
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
- /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if00-port0:/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if00-port0
- /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if01-port0:/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if01-port0
linux can see my HUSBZB-1 adapter:
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 002 Device 003: ID 8087:07dc Intel Corp.
Bus 002 Device 002: ID 10c4:8a2a Silicon Labs HubZ Smart Home Controller
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
When I try and add the integration, it goes like this.
- The adapter shows up in the dropdown.
- I select the zigbee port and submit.
- It spins for a while, then comes back and asks for my radio type.
- I pick the one that lists HUSBZB-1, and submit, then it comes back with a “Settings” dialog already filled it.
- It looks ok to me, but when I submit it just comes back with a “failed to connect” error:
I’ve also tried plugging in the apparently preferable “by id” form (/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if01-port0) as the device path (I mapped those in my docker-compose.yml too), but I get the same error.
I’ve tried starting the container by using sudo, in case it is a privs problem, but that doesn’t seem to have helped. What am I missing here?
I don’t see anything suspicious in my syslog, other than a couple of already exists in privileged mode messages that seem ok:
Sep 5 11:36:04 chipmunk dockerd[762]: time="2021-09-05T11:36:04.803994908-04:00" level=warning msg="path in container /dev/ttyUSB0 already exists in privileged mode" container=ff9c21f65f7d768dda4a2f999359c0577fa999673a15e5356063f0950ac1f566
Sep 5 11:36:04 chipmunk dockerd[762]: time="2021-09-05T11:36:04.804072798-04:00" level=warning msg="path in container /dev/ttyUSB1 already exists in privileged mode" container=ff9c21f65f7d768dda4a2f999359c0577fa999673a15e5356063f0950ac1f566
Sep 5 11:36:04 chipmunk dockerd[762]: time="2021-09-05T11:36:04.804106409-04:00" level=warning msg="path in container /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if00-port0 already exists in privileged mode" container=ff9c21f65f7d768dda4a2f999359c0577fa999673a15e5356063f0950ac1f566
Sep 5 11:36:04 chipmunk dockerd[762]: time="2021-09-05T11:36:04.804143320-04:00" level=warning msg="path in container /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31200456-if01-port0 already exists in privileged mode" container=ff9c21f65f7d768dda4a2f999359c0577fa999673a15e5356063f0950ac1f566
If anyone’s got some ideas, I would love to hear them.
I have screenshots, but I’m only allowed to include 1 in this post.
