Debugpy not starting: '<' not supported between instances of 'NoneType' and 'int'
I’ve set up HA Core in docker using the latest homeassistant/home-assistant official image (version 2024.12.0) and have added ‘debugpy:’ to configuration.yaml. The container runs in host mode and everything is working well except debugpy doesn’t start. In the log I get:
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:526
First occurred: 1:01:05 PM (1 occurrences)
Last logged: 1:01:05 PM
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: '<' not supported between instances of 'NoneType' and 'int'
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/_pydevd_sys_monitoring/_pydevd_sys_monitoring.py", line 455, in _get_code_line_info
    return _cache[code_obj]
KeyError: <code object _worker at 0x724f5cb0ed00, file "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 69>
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 764, in _async_call_service_step
    response_data = await self._async_run_long_action(
    ...<9 lines>...
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 727, in _async_run_long_action
    return await long_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1110, in _async_admin_handler
    await result
  File "/usr/src/homeassistant/homeassistant/components/debugpy/__init__.py", line 50, in debug_start
    await hass.async_add_executor_job(
        debugpy.listen, (conf[CONF_HOST], conf[CONF_PORT])
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.13/site-packages/debugpy/public_api.py", line 31, in wrapper
    return wrapped(*args, **kwargs)
  File "/usr/local/lib/python3.13/site-packages/debugpy/server/api.py", line 143, in debug
    log.reraise_exception("{0}() failed:", func.__name__, level="info")
  File "/usr/local/lib/python3.13/site-packages/debugpy/server/api.py", line 141, in debug
    return func(address, settrace_kwargs, **kwargs)
  File "/usr/local/lib/python3.13/site-packages/debugpy/server/api.py", line 282, in listen
    _settrace(
        host=server_host,
    ...<4 lines>...
        **settrace_kwargs
  File "/usr/local/lib/python3.13/site-packages/debugpy/server/api.py", line 45, in _settrace
    return pydevd.settrace(*args, **kwargs)
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/pydevd.py", line 3025, in settrace
    _locked_settrace(
        host,
    ...<14 lines>...
        notify_stdin=notify_stdin,
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/pydevd.py", line 3152, in _locked_settrace
    py_db.set_tracing_for_untraced_contexts()
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/pydevd.py", line 1226, in set_tracing_for_untraced_contexts
    self.set_trace_for_frame_and_parents(thread_ident, frame)
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/pydevd.py", line 2418, in set_trace_for_frame_and_parents
    pydevd_sys_monitoring.enable_code_tracing(thread_ident, frame.f_code, frame)
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/_pydevd_sys_monitoring/_pydevd_sys_monitoring.py", line 701, in enable_code_tracing
    func_code_info: FuncCodeInfo = _get_func_code_info(code, frame)
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/_pydevd_sys_monitoring/_pydevd_sys_monitoring.py", line 525, in _get_func_code_info
    code_line_info = _get_code_line_info(code_obj)
  File "/usr/local/lib/python3.13/site-packages/debugpy/_vendored/pydevd/_pydevd_sys_monitoring/_pydevd_sys_monitoring.py", line 465, in _get_code_line_info
    first_line = min(line_to_offset)
TypeError: '<' not supported between instances of 'NoneType' and 'int'
I have absolutely no idea on how to go about this. Can anybody help?
Filed the issue.
