I’m using the modbus integration to control a temperature controller. New temp setting must be submitted to the modbus.write_register service with the ‘value’ in IEEE754 32-bit floating point format. Ex (sets temp to 75):
service: modbus.write_register
value: [0x4296,0x0000]
hub: modbus_hub
unit: 2
address: 0
For my use case, I’ll be getting decimal values from the user and need to convert to the required format. I assume a template of some sort is the way to go, but it doesn’t appear there’s a simple filter for this. How would you approach it?
