Would it be possible for the Deconz addon to be able to specify an external URL for Deconz instead of the internal docker URL?
My use-case is the following. I have a dedicated Deconz installation (on a TinkerBoard) because I don’t want the lights to stop working whenever I mess with Home-Assistant (WAF…).
I can of course access Deconz directly from my internal network. But I would like to access it through the Home Assistant framework (using the Ingress feature).
I don’t understand the request here. The addon would be deconz running on the same machine as home assistant. Without addon deconz can run anywhere. The integration supports both methods
