something happend with my server, hdd crash and even die conbee stick was damaged, dont know what happend and dont got any backup (there was a hass backup but if im restoring that i cant connect anymore -.-)
soooo ok i bought a new stick und put it in another device (a raspberry this time) … installed hassio, duckdns and the deconz addon. now the phoscon app showes 2 hubs the old one and the new … how the fuck it this even possible with a new stick and a new whole computer fireing it up?
but now the new connected lights dont show up in hass
hass log:
21-04-22 21:49:39 ERROR (MainThread) [supervisor.utils] Can't execute stop while a task is in progress
21-04-22 21:49:41 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-deconz with version 6.8.0
21-04-22 21:49:41 WARNING (MainThread) [supervisor.addons.addon] core_deconz is already running!
21-04-22 21:49:43 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.1:8099 ssl:default [Connect call failed ('172.30.33.1', 8099)]
21-04-22 21:49:52 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.1:8099 ssl:default [Connect call failed ('172.30.33.1', 8099)]
deconz log:
(Make sure 'QTextCursor' is registered using qRegisterMetaType().)
22:01:17:092 COM detected application
PROTO: CRC error
PROTO: CRC error
22:01:17:139 Device firmware version 0x264A0700 ConBee II
22:01:17:144 unlocked max nodes: 200
22:01:17:196 invalid current channel 0 (TODO)
22:01:17:271 Announced to internet https://phoscon.de/discover
22:01:17:273 discovery server date: Thu, 22 Apr 2021 22:01:17 GMT
22:01:17:275 local time seems to be ok
22:01:17:284 Device protocol version: 0x010B
22:01:17:310 CTRL restore cached node 0x00212effff051978
22:01:17:311 Node zombie state changed 0x00212effff051978
22:01:17:315 new node - ext: 0x00212effff051978, nwk: 0x0000
22:01:17:439 Current channel 15
22:01:17:454 CTRL got nwk update id 0
22:01:17:459 CTRL ANT_CTRL 0x03
22:01:17:499 Device protocol version: 0x010B
22:01:17:608 Current channel 15
22:01:17:623 CTRL got nwk update id 0
22:01:17:629 CTRL ANT_CTRL 0x03
22:01:17:675 ZCL attribute report 0x7CB03EAA0A006BC7 for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
22:01:17:689 ZCL attribute report 0x7CB03EAA00B0FA09 for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
22:01:17:702 ZCL attribute report 0x7CB03EAA0A0063DF for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
22:01:20:764 ZCL attribute report 0xF0D1B8000014828A for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:01:27:105 channel is 15 but should be 25, start channel change
22:01:27:107 Skip automatic channel change, TODO warn user
22:01:27:187 dev /dev/ttyAMA0
22:01:27:194 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26660700.bin.GCF
22:01:27:195 GW firmware version: 0x264a0700
22:01:27:196 GW firmware version shall be updated to: 0x26660700
22:01:37:105 channel is 15 but should be 25, start channel change
22:01:37:106 Skip automatic channel change, TODO warn user
22:01:38:048 unknown node 0x00158D0004072CB1 (0x0768), lqi: 255
22:01:38:049 APS-DATA.indication from unknown node 0x00158D0004072CB1
22:01:38:051 ZCL attribute report 0x00158D0004072CB1 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:01:38:052 0x00158D0004072CB1 extract Xiaomi special attribute 0xFF01
22:01:38:054 01 battery 2955 (0x0B8B)
22:01:38:055 04 unknown 5032 (0x13A8)
22:01:38:056 05 RSSI dB (?) 16 (0x0010)
22:01:38:057 06 LQI (?) 352190726144 (0x5200340000)
22:01:38:058 64 temperature 2054
22:01:38:059 65 humidity 4657
22:01:38:059 0a Parent NWK 0 (0x0000)
22:01:38:601 new node - ext: 0x14b457fffe4fa4ed, nwk: 0x193A
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/index.html HTTP/1.1" 200 113149 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/ingress.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/blinds-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/generals-undefined.json HTTP/1.1" 404 156 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/gateway-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/login.html?1619128902422= HTTP/1.1" 200 27120 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/help-undefined.json HTTP/1.1" 404 153 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/lights-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/login-undefined.json HTTP/1.1" 404 154 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/nav-undefined.json HTTP/1.1" 404 154 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/network-undefined.json HTTP/1.1" 404 156 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/scenesEditor-undefined.json HTTP/1.1" 404 160 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/sensors-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:42 +0000] "GET /pwa/language/undefined/switches-undefined.json HTTP/1.1" 404 157 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/help-undefined.json HTTP/1.1" 404 153 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/lights-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/login-undefined.json HTTP/1.1" 404 154 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/nav-undefined.json HTTP/1.1" 404 154 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/network-undefined.json HTTP/1.1" 404 156 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/scenesEditor-undefined.json HTTP/1.1" 404 160 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/sensors-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/switches-undefined.json HTTP/1.1" 404 157 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/lights-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/generals-undefined.json HTTP/1.1" 404 156 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/blinds-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/help-undefined.json HTTP/1.1" 404 153 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/gateway-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/login-undefined.json HTTP/1.1" 404 154 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/nav-undefined.json HTTP/1.1" 404 154 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/scenesEditor-undefined.json HTTP/1.1" 404 160 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/switches-undefined.json HTTP/1.1" 404 157 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/network-undefined.json HTTP/1.1" 404 156 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:43 +0000] "GET /pwa/language/undefined/sensors-undefined.json HTTP/1.1" 404 155 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
22:01:44:430 device state timeout ignored in state 3
22:01:44:604 Skip idle timer callback, too early: elapsed 910 msec
172.30.32.2 - - [22/Apr/2021:22:01:44 +0000] "GET /api/config HTTP/1.1" 200 265 "https://alexanderpct.duckdns.org:8123/api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/pwa/login.html?1619128902422" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
22:01:47:104 channel is 15 but should be 25, start channel change
22:01:47:106 Skip automatic channel change, TODO warn user
22:01:48:143 saved node state in 4 ms
22:01:51:005 sync() in 2860 ms
172.30.32.2 - - [22/Apr/2021:22:01:51 +0000] "GET /api/config?_=1619128910010 HTTP/1.1" 200 265 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
172.30.32.2 - - [22/Apr/2021:22:01:51 +0000] "GET /api/hassio_ingress/vnYLv55Ah5OK1FXbkR8LQYW8sY9YpCkm2V1_zVOEa3k/api/config?_=1619128910924 HTTP/1.1" 403 140 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36"
22:01:51:587 new node - ext: 0xccccccfffede03f1, nwk: 0x053A
22:01:56:124 Current channel 15
22:01:56:130 CTRL got nwk update id 0
22:01:56:137 Device TTL 2841 s flags: 0x7
22:01:57:105 channel is 15 but should be 25, start channel change
22:01:57:106 Skip automatic channel change, TODO warn user
22:02:01:131 saved node state in 4 ms
22:02:01:333 sync() in 200 ms
22:02:02:105 Skip idle timer callback, too early: elapsed 769 msec
