I purchased the ConBee usb stick and I understand that I need to install deCONZ software to make it work.
I would like to do that on the same raspberry pi that I have my hassio running. Documentation says that I need to " Use community container by Marthoc for your deCONZ needs. It works both as a standalone container as well as with HASS.io.". How can I do that?
I looked around in the forum but I only found people that straggled a lot with it and a few who succeeded with things that I tried and failed. Is there any reliable documentation on this topic?
Unfortunately I was a bit unclear in those details. It uses the same base but you need to use the add-on repo. If you google for marthoc deconz add-on you will find it. It just got accepted upstream as an official add-on so it will soon be even simpler to install.
In my case, since I’m using conbee, I installed directly and then changed the deconz_device config option, as described in the documentation.
The value in my case was “/dev/ttyUSB0”. To figure this value out go to Hassio.io -> System and click hardware. Take the usb dongle in and out and see how it appears in the hardware configuration.
After all that I just started the add-on and it worked!
I just received the Conbee stick and I’m trying to use it with Hassio 0.88.1 and the addon from martoc on Github (I’ve tried also the default one).
I can pair all my devices (mainly Xiaomi Sensor Mijia) with the Deconz app on Windows (USB stick is connected to my PC), but if I try to pair with Phoscon app (both on Windows or connected to my Intel NUC with Hassio), I have no success.
Is there a way to pair with Deconz and restore the configuration on Phoscon app?
if you add devices in phoscon, make sure you hold them verry close to the conbee stick
i also struggled with this the first time, i bought some ikea sensors and osram switches, but when adding in phoscam, i never found those
then i kept them like verry close, 10 cm, and then it synched
after that, you can place it where you want
