But I appreciate the work you have done
I guess the bug where it give a random name to the entity in HA, when you name it correctly in deCONZ also is fixed?
in deCONZ, i called the Innr Smartplug “innr_smartplug”.
In HA, it was created as “switch.innr_smartplug”, “sensor.consumption_18” and “sensor.power_18”
Hey there! I am pretty new to Home Assistant, but I think it’s totally awesome!
I had to dig up this thread because I have exactly the same problem as Smus had. I run hassio 0.103.5 on a raspi 3b+ with a conbee 2 stick. Today I installed an innr SP120 and I only get a power and a consumption sensor but no voltage and current one.
One thing that is suspicious though is that voltage and current show up under the power graph (watts) on the dashboard.
So does anyone know what I’m doing wrong here? Thanks!
