Blueprint to support the Aqara Opple switch 3 bands (WXCJKG13LM).
The following events are currently supported
- single press to turn ON or OFF the lights
- long press to increase or decrease the brightness smoothly until released
- double press to adjust the brightness to 100% or 10%
In addition, you also have the choice to determine a forced brightness for when you turn on the lights.
Get started
Import this blueprint into your Home Assistant instance, with a simple click via the button below.
The code:
blueprint:
name: deCONZ - Aqara Opple (6 way) remote for lights
description: |
Control 3 lights with an Aqara Opple switch 3 bands (WXCJKG13LM).
Each band controls one light/group.
domain: automation
input:
remote:
description: Opple remote to use
selector:
device:
integration: deconz
manufacturer: LUMI
model: lumi.remote.b686opcn01
light_1:
description: The first light(s group) to control
selector:
entity:
domain: light
light_2:
description: The second light(s group) to control
selector:
entity:
domain: light
light_3:
description: The third light(s group) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description: >
Force the brightness to the set level below, when the "on" button on
the remote is pushed and lights turn on.
default: false
selector:
boolean:
brightness:
description: Brightness of the light(s) when turning on
default: 50
selector:
number:
min: 0
max: 100
mode: slider
step: 1
unit_of_measurement: "%"
mode: restart
max_exceeded: silent
variables:
force_brightness: !input force_brightness
- platform: event
event_type: deconz_event
event_data:
device_id: !input 'remote'
- variables:
event: '{{ trigger.event.data.event }}'
- choose:
# ---------------------------- TURN ON OR OFF ---------------------------- #
- conditions:
- '{{ event == 1002 }}'
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.turn_on
target: !input 'light_1'
transition: 1
brightness_pct: !input brightness
default:
data: {}
- conditions:
- '{{ event == 2002 }}'
sequence:
- service: light.turn_off
data: {}
- conditions:
- '{{ event == 3002 }}'
sequence:
- choose:
sequence:
target: !input 'light_2'
transition: 1
default:
data: {}
- conditions:
- '{{ event == 4002 }}'
sequence:
data: {}
- conditions:
- '{{ event == 5002 }}'
sequence:
- choose:
sequence:
target: !input 'light_3'
transition: 1
default:
data: {}
- conditions:
- '{{ event == 6002 }}'
sequence:
data: {}
# ---------------------------- INCREASE OR DECREASE BRIGHTNESS ---------------------------- #
- conditions:
- '{{ event == 1001 }}'
sequence:
- repeat:
until:
- condition: template
value_template: '{{ event == 1003 }}'
sequence:
brightness_step_pct: 10
transition: 0.5
- delay: '0.2'
- conditions:
- '{{ event == 2001 }}'
sequence:
- repeat:
until:
value_template: '{{ event == 2003 }}'
sequence:
brightness_step_pct: -10
transition: 0.5
- delay: '1'
- conditions:
- '{{ event == 3001 }}'
sequence:
- repeat:
until:
value_template: '{{ event == 3003 }}'
sequence:
- delay: '0.2'
- conditions:
- '{{ event == 4001 }}'
sequence:
- repeat:
until:
value_template: '{{ event == 4003 }}'
sequence:
- delay: '1'
- conditions:
- '{{ event == 5001 }}'
sequence:
- repeat:
until:
value_template: '{{ event == 5003 }}'
sequence:
- delay: '0.2'
- conditions:
- '{{ event == 6001 }}'
sequence:
- repeat:
until:
value_template: '{{ event == 6003 }}'
sequence:
- delay: '1'
# ---------------------------- MAX OR MIN BRIGHTNESS ---------------------------- #
# ---------- MAX ---------- #
- conditions:
- '{{ event == 1004 }}'
sequence:
brightness_pct: 100
transition: 0.5
- conditions:
- '{{ event == 3004 }}'
sequence:
brightness_pct: 100
transition: 0.5
- conditions:
- '{{ event == 5004 }}'
sequence:
brightness_pct: 100
transition: 0.5
# ---------- MIN ---------- #
- conditions:
- '{{ event == 2004 }}'
sequence:
brightness_pct: 10
transition: 0.5
- conditions:
- '{{ event == 4004 }}'
sequence:
brightness_pct: 10
transition: 0.5
- conditions:
- '{{ event == 6004 }}'
sequence:
brightness_pct: 10
transition: 0.5
Notes
It has been tested and works fine. If you run into problems or if you want me to add more events in the blueprint, please let me know
